Question about Zebra Printer 140-751-00000
We are using Bartender 9.01 and we are have printing issues we are getting the following 2 errors does anyone know what 3700 error means? 9/14/2010 7:29:34 3700 Error Printer OK BarTender cannot use printer 'WHSE FC' to design, print or export a label format due to a printer setup problem. There are several possible reasons: 1) The printer is not turned on or is off line. Try printing a test page from Windows. 2) The printer does not exist on your system or network. 3) Security settings prevent access to the printer. 4) If you use a network for printing, there may be a problem with the network connection or the printer driver. 5) There may not be enough memory available. Try closing files and programs you aren't using. 6) The printer driver is installed incorrectly. Try reinstalling the printer driver. 9/14/2010 7:29:34 3711 Error Printer Close The printer "WHSE FC" that was used to design this format is no longer installed or the printer name has been changed.
SOURCE: out of order printing..
When I try to print some slip-on the machine begin, but at the half way of the label it's write end off paper, but I still have a lot of paper in the machine, please help me.
Posted on May 13, 2011
bartech9
  • 155 Answers
SOURCE: Zebra Z4m+ won't print from Bartender 9.01
BarTender uses its own drivers for each model of printer you must install the correct driver, because there are differences in some commands a printer to another.
Posted on Mar 10, 2009
  • 62 Answers
SOURCE: Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Posted on Jul 13, 2009
bartech9
  • 155 Answers
SOURCE: zebra z4mplus
It happens that the printer is not calibrated to the labels you want to print. A quick fix is to restart the printer with its factory settings, press FEED and PAUSE when you turn the printer, release the keys when label feeding.
Roberto Martinez
Posted on Oct 06, 2009
  • 97 Answers
SOURCE: Zebra 105SE printer will print text and images
Bartender is a pretty good label software package - strange that you're having problems with a barcode. Are you by any chance trying to print a 2D barcode such as Datamatrix ? If that's true, then the problem is that the datamatrix barcode is not a resident barcode in the firmware version of that printer which is an older model. There should be a choice in bartender, in the properties of the barcode field that allows you to send the barcode as an image or graphic. The barcode will then print.
If you're trying to print a linear barcode (C39 or C128 or UPC for example) and it they won't print with the steps you have taken, then something is definetly wrong. Another option would be to take your label format and print-to-file instead of print-to-printer. There should be an option on the print screen for this. By then opening the file, the ZPL (Zebra's programming language) can then be examined to see exactly what is being sent to the printer.
Hope this helps !
Posted on Apr 17, 2010
Do the Huawei S2700/3700/5700/6700 Support the Optical Modules of Other Vendors?
The S2700/3700/5700/6700 can use only the certificated optical modules. If an uncertificated
optical module is used, an error may occur and Huawei is not responsible for it. Huawei Switch Price Buy Huawei Quidway Switches Huanetwork com
Aug 27, 2014 | Huawei Computers & Internet
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
Hp printer 2515 allocating an error code - 00000000 reason being for this error code?
Based on the descritpion, it appears that you are getting an error message "error page 00000000" before normal print job. I will be happy to fix this issue.
1) What do you mean by "prints page with error 00000000"?
2) Have you made any changes on the computer prior to this issue?
I would suggest you to follow the steps to run the troubleshooter and check if the issue persists.
Open the Printer troubleshooter
CBR Tech Solutions or http://www.cbrtechsolutions.com
Aug 12, 2013 | Office Equipment & Supplies
Trendnet te100 HP P2035 not printing
1. What is the exact error message or error code?
2. Have you made any changes to the computer prior to this issue?
I would suggest you to refer the following Microsoft article and check if it helps.
Printer problems in Windows:
for more help visit CBR Tech Solutions
Apr 17, 2012 | Trendware TRENDnet TE100-P1U Print Server
Monarch Paxar 9855 Printing Errors
can you try a serial connection, what type of operating system are you using?
Aug 07, 2009 | Monarch 9855 Thermal Printer
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Printig problem
This is an driver (in some parts memory) problem.
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1258893
Author Subject: PCL XL error Subsystem: KERNEL Error: IllegalOperatorSequence favorites_add.gif Clinton Griffin
Aug 13, 2008 02:59:02 GMT I purchased a HP Color LaserJet CM1312nfi MFP and connected to my HPLaptop with Vista 64-bit operating system and received the followingerrors when trying to print from most applications:
PCL XL error
Subsystem: KERNEL
After many hours of reinstalling the drivers, the firmware, on thephone with Microsoft and on the phone with HP to no avail, I discoveredthe work around myself.
I downloaded the HP Universal Print Driver Series for Windows Vista 64-Bit and this driver works! Here is the link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=
us&prodNameId=3271558&prodTypeId=18972&prodSeriesId=503548&swLang=8&ta
skId=135&swEnvOID=2100
This solved my problem and hopefully it helps you.
- Clint
Aug 15, 2008 23:27:43 GMT Unassigned
Clint,
Just so you know what you were dealing with, as it may resurface, seeboth of Chris H's replies in this thread. Since the error was the same,it was a driver fault, and replacing the driver, not necessarily thatspecific UPD driver, that fixed it.
http://forums12.itrc.hp.com/service/forums/bizsupport/questionanswer.do;HP-FORUMS-S-WPA-IDX=H37N4f36mF4yp5t5NKsNBSL4PnhvrlHJnkHP21LmvMQkc43snv3j!-204454619
6!-1667575472?threadId=1203940&admit=109447627+1203190733494+28353475
I'm glad it's working for you.
Pat
Sep 19, 2008 03:31:26 GMT Unassigned
Update:
I continued to look at the issue and now think the problem is not thedriver, but the application software. Using the 64-bit driver for theCM1312:
1. I can print color using Paint and text using Notepad.
2. I cannot print from Adobe 9, IE 7 and Office 2007 (downloaded 9/17/08) in color. If I do I get the
PCL XL error
Subsytem: KERNEL
Error: Illegal Operator Sequence
Operator: EndSession
Position: 15
3. I CAN print all the products in 2 if I switch to grayscale.
4. I can print screen captures from the products in 2 using Paint -which may be my workaround until HP and Microsoft get together on asolution.
So does anyone from HP monitor this and report the issue and resolve it?
So theThe problem for me is color printing in Microsoft products.
Dec 20, 2008 | HP LaserJet 4250n Printer
Casio CE-3700 giving E008 errors!
Hi.
Yes, it definitely is the CLERK function. When you enter 0 CLK#, you are just logging off (which has already been done), so that is normal for it to accept that. If you can't get in with 1 CLK# then I'd say someone has setup special codes for this machine (PIN numbers). You will need to do a prog. read. Also, if you have four raised CLERK buttons just below the keylock, one of them should be pressed down. (they are an option on some versions). Try 1 CLK# or 2 CLK# or 3 CLK# ... up to 7. If none will log you on, let me know, and I'll tell you how to do a read on it.
Mark
Apr 30, 2008 | Casio Parts Cash Register PC Desktop
59.0A error in hp color laserjet 3700
All 59.XX error codes have to do with a motor failure of some type. I don't know anything specific about 59.0A but 59.A0 means that either the drum motor failed to start or something bad happened while it was rotating. If you feel like tackling it yourself you can try reseating all the connections to the drum motor and the DC controller board. Other possibilities could be a bad drum motor or a bad DC controller. HP says you can also get this message when the tranfer unit is missing or improperly installed.
If you don't feel like tackling it yourself then it's off to a repair shop unless it's under warranty, in that case call HP.
Jan 19, 2008 | HP Color LaserJet 3500 Printer
Error messages
Any of the following Error Messages "D.EMG, C.EMG, R.EMG, L.EMG" indicate a mechanical failure in the camcorder. The following steps may resolve the issue. 1. Eject the tape 2. Set to OFF 3. Detach the battery 4. Reattach the battery
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Zebra Printer 140-751-00000 Logo
1,835 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
