Question about JVC Televison & Video
My JVC AV-48WP30 picture is distorted vertically to about half the screen height. If I turn the tv on and off a few times, sometimes it will correct itself, until I turn it off again.
  • JVC Master
  • 8,617 Answers
Try resoldering the vertical output IC that should correct the issue repeated off and on cycles often tend to bridge the solder connection causeing the set to work untill power is cut off.
Posted on May 16, 2008
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 problem starting up
The old video card has seen better days, methinks. All those symptoms lead one to conclude it needs a 'substitute' to enter the field, or call a long TV time out(too much pro and super bowl isms, eh?)..
Are you planning on doing this yourself?
Feb 11, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 foggy image
Check convergence adjust screen after picture distorts.
Description sounds like shading from a defective convergence circuit. If you replaced STK392-110 with 150, then re-install new 110's, or new 150's and re-design the circuit and change low-ohm resistor values to compensate for different IC's. It is not the same as a brighter light bulb.
See if the picture is in the CONVERGENCE GALLERY
easyab
Oct 18, 2008 | JVC AV-48WP30 48" Rear Projection...
Jvc av27d201 tv screen problem
You need to have the vertical output IC pins resoldered
Jul 16, 2008 | JVC AV-27D201 27" TV
What's the difference between AV-48WP30 and AV-WP74
They are both the same size screen. (48" diagonally)
width: 106.3cm
height: 59.8cm
C-Dog
Feb 01, 2008 | JVC AV-48WP30 48" Rear Projection...
PLURED PICTURE
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Jvc tv on button flashing on av 48wp34
Use remote, sounds like Tv is in child lock
Dec 21, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
Jvc av-27730 27"
One thing you should not do with electronic devices which have a start up proceedure is to turn the power off, and then on again without a wait of about five minutes. Some equipment manuals warn you about this, and specify a longer period. The start-up has to have time to reset. It will be more likely to reset if you do not leave it on standby, and even unplug it. In your TVs case you need to describe the distorted picture as it may give a clue to a fault, or incorrect start-up. The horizontal line indicates the frame timebase had stopped working. No picture could be a fuse blown inside the set, or a timed cutout which may reset after a time. Try after several hours to see if it comes on. If it is just the frame timebase (vertical) it is worth repairing.
Oct 22, 2006 | JVC AV-27230 27" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
