Question about Zenith FS-122S 35mm SLR Camera
I have an old zenith ttl and an 11 both in good order but I need a new battery compartment cover for each of them. where can I get these parts ?
    Brigadier General:
  • 3,006 Answers
The only place to get them is by obtaining other complete models as spares donors. Spare parts are long discontinued, and as most Zeniths are completely without resale value and there are so few remaining users nobody is able to make a viable business out of breaking them for spares.
You don't have to pay for a donor, almost every Zenith and Praktica I've ever owned has come from my local FreeCycle and Freegle groups and the rest cost almost nothing from boot sales and charity/thrift shops.
Posted on Sep 14, 2010
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
New batteries still no power-up
Check the contact in the batt compartment for obstructions or corrosion etc. No power means broken circuitry - either physical dislodgement of electronic/ electrical parts or damaged electronic components.
Apr 01, 2013 | Canon Speedlite 430EX TTL Flash
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
Where can i get Pogo Radio YourWay LX Replacement Battery ...
You are going to have to modify the battery compartment since Pogo is no longer in business. You will need a Dremel to cut the back plane of the battery compartment out. The back plain is the plastic piece that the separate the circuit and battery compartment. When you insert the battery it is inserted until it stop against the back plain. You will need to remove the back cover to cut the plain out. Once this is done just take teh old battery to a battery store for a replacement. the voltage should be 3.7 volts, and as close to the MA as possible. Also make sure that the new battery has the right connector or otherwise you will have to reuse the connector from the old battery buy cutting the wires as close to the old battery as possible and resoldering to the new battery. good luck
Jan 22, 2011 | Pogo Radio YourWay MP3 Player
Battery cover latch broken , small lugs to hold cover in place next to the well. Is there a battery compartment available to replace it?
I've tried to find the parts on the internet, but had no luck. Here's what I would do in that case...you can get an "as-is" camera on ebay for anywhere from $11 to maybe $25, depending on how the bid goes. Just make sure that camera has a good battery cover- you can query the seller about that. Then, you can salvage the good battery cover. You will have to take the camera apart, but once you take the bad one apart, you'll understand how it fits together and be able to reassemble it easier. Other than that, your options are repair, and I'm not sure how much a shop would charge you, but often it's just better to buy a new camera, in that case. That's about all I can think of, good luck!
Apr 18, 2010 | Casio QV-R51 Digital Camera
Door of the Battery compartment broken
To buy a replacement battery door is easy - go to Ebay - buy the replacement or, for the same price (around $20), buy an old camera just for the sake of the door. The second part, replace the door is much more difficult but I found out how to do it. The door has a hinge (a 1 inch long pin) which needs to be slid out from the camera to take the old door out and then to insert the new door. However, this pin just comes out if you open up the camera. To open it up, you need to remove 6 screws with Philips precision screw driver 1.6 mm ($7 at Radioshack) - there are 2 screws on 3 sides of the camera. After removing these screws carefully separate the two parts of the camera - you just need a gap of (maybe ) 1/16, just enough for the pin to slide out, which can be done forcing it out with a sharp knife. After the pin is removed, remove the old door, put the new door in place, put the pin back and use some pressure to join the two parts of the camera together. They join back with a click, put the 6 screws back and it is done.
Jul 11, 2008 | Cameras
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Battery compartment cover
They really want you to buy a new camera instead!
TAPE it shut!
Otherwise you can sometimes find equipment sold 'as-is' for parts on eBay or other internet sites.
Do a web-search for it.
Nov 01, 2007 | Fuji FinePix S602 Zoom Digital Camera
Flash won't fire on p-ttl mode
The AF360 can be in TTL mode until it is mounted on a P-TTL compatible camera and turned on, then it senses the camera and goes to P-TTL. However, sometimes in the past when I got TTL and it should have been PTTL it meant that either the batteries were not connected properly (I know, sounds strange, but check the battery compartment cover to make sure it is seated properly and make sure that the batteries are all in proper position), or that the AF360's contact pins were not all making proper contact with the shoe or extension. Beyond that it could be a faulty flash. You have swapped lenses and cameras with the same result, how about swapping flash? Unfortunately that may be your problem.
Sep 08, 2005 | Pentax AF-360 FGZ TTL Flash
Zenith FS-122S 35mm SLR Camera Logo
201 people viewed this question
Top Zenith Photography Experts
Tony
Are you a Zenith Photography Expert? Answer questions, earn points and help others
