Question about Nikon Camo (7074) Tripod
Hi the part I am looking for is the part on the very top where the camera screws on to the tripod it looks like is was held on by a screw but the part that sit down in the top has broken off. Can I get a replacement?
  • 685 Answers
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod.
Posted on Sep 23, 2010
The screws on my tripod will not tightened
Take out the whole Camera Plate. there is a plastic cap on the top of the tripoid, right by the end of your tripod extender, that comes out with a little pulling it. Now, have a look at the end of the knob housing from which your screw accidentaly came out. You will see a perfect spot in wich you need to re- insert the nut that came out. Once you do it, all you need to do is to re- insert the knob back into place, and it will "bite" the nut again at the end of the housing. Re- install the whole plate back on top of your tripod. Finally, put the plastic cap back at the top. You might need to gently tap it in. Done deal . Problem resolved ! Enjoy your tripod !
Jan 21, 2012 | Zeikos ZETR57A Tripod
Hoe to take head off of tripod
The heS IA MOUNTED ON THE BASE WITH A 3/8" SXREW STUD (BASE) AND FMEAL (HEAD). i IS HELD IN PLACE BY TGHREE SCREWS in the baSE. rAISE TRIPOD CENTER COLUMN A FEW INCHES, loodrn the three set screws, then twist head counter-clockwise(if looking at top from birds=eye view.
May 05, 2011 | Bogen Manfrotto 475B Black Tripod 475 USA
Remove 3130 head from 3021 tripod
The head is mounted on the base by a 3/8" screw. The head is held in place by 3 set screws in the base. Turn tripod upside down, loosen (or if completely removed, do not lose them) those 3 screws, turn tripod rightside up and unscrew head from tripod. If unable to turn head, loosen screws a little more. If scres are removed and heaf still not comeing off, Use pipe wrench or afjustable pliers wrapped in cloth to preven maring and loosen. (looking from top, or birds eye view, turn head counter-clockwise
Apr 23, 2011 | Bogen Manfrotto 3130 Micro Fluid QR Head...
The leg axles of my Manfrotto 190PROB are loose and the tripod legs will not stay spread when I carry it. How do I take off the top yoke to access the allen screws to tighten the leg pivots?
The top yoke of a Manfrotto 190PROB is held in place by a spring mechanism. The spring mechanism is just behind the screw that tightens the center column. First remove the center collumn. Inside the to yoke (where the centre column was) there is a small hole. Poke something in that hole to push back the spring mechanism. You should now be able to push the yoke out towards the top. When the yoke is removed you will see the three screws that keep the hinges tight. Reasembly is straight forward. Simply re-enter the yoke in such a was as to push back the spring mechanism.
Dec 12, 2010 | Manfrotto 190XPROB PRO ALU Tripod
Attachment at base of camera - SLIK 88M
The standard tripod screw mount is 1/4"-20tpi. 1/4"-20 UNC will also work. You should be able to find such bolts at your local hardware store.
Jul 27, 2009 | Nikon Slik 822 Tripod
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Mar 17, 2009 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Mounting camera on Fotomate Tripod
Try adding a flexible filler, such as cork or card stock, or a few buisness cards work as well at times. Cork and card stock are both avaible at a hobby store. Place the mounting bolt through the filler, and snug it up. it should fill the gap you have between the camera and plate. Also take care of the sloppyness of the screw. Good luck.
Jul 15, 2008 | Photography
Nikon Camo (7074) Tripod Logo
147 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
