Question about Mitsubishi MSH09TW Air Conditioner
My Mr Slim Model # MSH09TW suddenly is turn off in the middle of the night. Then comes back on for 5 minutes, then stop and blows nothing( with the green light on). I've had the HVAC people service the unit, tested and did a setback, replaced the batteries in the controller and the problem still exists! What needs to be done?
  • 2,299 Answers
It sounds like the thermal overload it kicking it out. The thermal overload is to keep it from starting a fire. Something is getting hot inside the unit.
Posted on Sep 14, 2010
Mr.Slim split unit-indoor blower bearing squealing, any easy tips to lube this, or strictly replacement?
All bearings in indoor motor are pre-lubricated. Only solution is to replace the bearings.
Jan 14, 2011 | Mitsubishi MSH09TW Air Conditioner
I have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
heatman101
Nov 19, 2010 | Mitsubishi Heating & Cooling
Mr. Slim is not blowing out cool air in 1 room, while the other 2 rooms, he's doing fine.
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 08, 2010 | Mitsubishi MSH09TW Air Conditioner
Mitsubishi Mr Slim Units Take 5+ minutes to start
this is not abnormal. you dont have to worry about the refrigerant freezing. it wont. Once your unit is given the call for heat it can take 5 minutes easily for the refrigerant to circulate and draw the btus from the ambient air. you can try to change the setting on your fan to medium but no higher.
Dec 11, 2009 | Heating & Cooling
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Inside fan not running in heat mode
i belive these units may have a cold air prevention sensor in them which wont allow fan ops until the coil reaches temp
Mar 04, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim msz-a17na won't turn on after power outtage
after a power outage, normally as power comes back in, it's a little bit high than normal.
with a dead set that you got, it would probably be the control transformer. the primary could have been burn by a spike voltage.( sudden rise in voltage above normal).
or im sure it has a fuse. check first the fuse. if the fuse is ok, then it would be the transformer.
tnx 4 using fixya,
Drcool
Nov 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MSH09TW Air Conditioner Logo
138 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
