Question about GE Profile Harmony DPGT750EC Electric Dryer
Blower & heat
Unit does not blow or heat most of the time , circuit board has been replaced twice.
  • 145 Answers
Most common problem on this unit is the blower motor. It needs replaced not the control board.
Posted on May 16, 2008
Unit not working correctly. The unit worked for the winter, few days ago I turn on the AC and noticed that it wasn't cooling like it should.
It's could be the board or a heat relay. See if you have 24 volts on "x2" im assuming, emergency heat when in cool mode if so it's the board. Or unhook black or x2 or your emergency heat from board and run unit in cool. If heat stays on its a relay
Jun 02, 2016 | Heating & Cooling
I have a Goodman GMH950904CXAC. Thermostat calls for heat. It comes on and runs fine for about 5 minutes, then the circulator blower shuts off, but burners and draft blower still run. After another 15...
4 flashes is an overheat situation most likely caused by the blower not blowing. The blower relay controls the blower function. It is part of the circuit board. I suspect a new board will take care of the problem if you don't find a lose wire or something simple.
Feb 27, 2010 | Goodman Heating & Cooling
We have a Janitrol gds80904bna less than 3 years old. We have had several repair people out here and none have a clue why the unit keeps running. No heat. Just fan. They want to replace several parts and I...
Make sure that there are no wires connected to the G terminal on the circuit board. There is a blower relay on the circuit board that is probably bad, replace board.
Dec 26, 2009 | Goodman GDS80904BNA Open Flame Heater
Induced Draft Blower Not Blowing- 3 Blinks on LED
Your doing well just right. When the call for heat is on the draft motor gets a call from the board to come on. When this happens if no voltage is present at the motor then you ahve abad baord. Replace it.
Nov 28, 2009 | Heating & Cooling
Armstrong 4PHP13E36P runs after heating element cools
There may be pins on the circuit board inside the air handler that you can adjust. First turn off the breaker then look inside at the board. They may say 30-45-60-90 etc. Put the pin on a lower number. Do you have a digital or programmable T-stat? There may be a setting in the T-stat setup program that allows for blower delay also. consult you installation instructions. Last if the blower isn't turning off at all then the relay on the circuit board is stuck closed and should be replaced.
Mar 10, 2009 | Heating & Cooling
Pk115t garage heater won't start
check all of the air filters and lines to start but it sounds like the CAD flame sensor.
Feb 02, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Armstrong v tech 91 furnace. will not make heat. when on unit runs continuosly no matter what thermistat is set at. could mother board be bad,replaced once already. cah this be done by the home owner to...
These furnaces goes thru 4--steps for complete run time.... step-1, the small draft inducer blower motor blows and prove thru the small air tube that sucks a switch close to tell the circuit board to go to step-2......the glow plug glows for 15 seconds and step 3 the gas valve opens and dump gas in the venturi tubes and lights off the glow plug and proves thru a flame sensor (pin with 1 electrical wire connection) on the last venturi tube which tells the circuit board to go to the last step 4--, to turn on the main blower fan after 90 seconds!. Where ever it stops at then thats where your problem is!
Sep 12, 2008 | Heating & Cooling
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
GE Profile Harmony DPGT750EC Electric Dryer Logo
54 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
