Question about Microwave Ovens
Wiring diagram for convection oven garland MCO-ED-10-S
Unit has no power
Check the door switch. Microwave will not turn on if door switch is faulty.
Mar 12, 2014 | GE Advantium 120 Convection/Microwave Oven
My electric lower oven doesn't get any heat.
Could be a lot of things, door lock switches, bad element, a fuse, the thermostat a broken wire or cold solder joint. etc
Good luck
Feb 20, 2014 | GE Profile 30 " Stainless Steel Built-In...
Need wiring diagram for microwave oven ,model sca1001hss 02
We have the service manual for this model and have uploaded it for you here.
You can find handy exploded views and order parts by model number here.
Sep 15, 2009 | GE Advantium SCA1001HSS Convection...
Looking fr wiring schematic JVM1490WH01
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 14, 2009 | GE JVM1490 Convection/Microwave Oven
Microwave part of my GE Sensor Convection Microwave doesn't work
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 22, 2008 | GE Advantium 120 Convection/Microwave Oven
PROBLEM WITH SHARP R-1874TF CONVECTION OVEN
sometimes an over heat will shut down the oven for a little bit but lets look at other things
i dont believe the board to be bad but i do believe the heating element inside is fried or a wire got fried by heat
if you know how to use ohm tester i would check heating element and wireing first
then try to see if the timer gave out
Dec 06, 2008 | Sharp R-1874 Convection/Microwave Oven
Service manual / wiring diagram
I need a Manual and parts list for a Bravetti K5345H Microwave-Convection Oven Please help!!!
Mar 03, 2008 | Microwave Ovens
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
Oven died while using convection feature
It may be the main fuse inside, or it may be the thermal cutout.
While a thermostat will reset after cooling, thermal cutouts (TCOs) are thermal fuses, one-time devices that must be replaced.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 21, 2007 | GE Advantium 120 Convection/Microwave Oven
Microwave Ovens Logo
263 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
