Question about E-Machines Computers & Internet
When the computer starts I get two errors at boot. #1 Check date and time settings #2 System CMOS shecksum bad-default configuration used What type of battery does the T1742 computer use?
    Scholar:
  • 181 Answers
Most motherboard used the button pin type of battery for the bios. Specifically, your board used the CR2032 , 3VDC battery. Just be sure that your PC is off when replacing the battery.
Good luck.
TedMac
Posted on Sep 15, 2010
Bios rom checksum error, boot block bios vI.0
Error BIOS ROM CHECKSUM - SYSTEM HALTED.
Cause Bad Hardware
Solution Unfortunately this indicates that your computer BIOS ROM chip or Motherboard is physically bad. It is recommended that you contact your computer manufacturer or take the computer into local service center for repair.
If you wish to repair this issue yourself the motherbard will need to be replaced.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values hopefully against a recent
If you have reset the CMOS memory you need to go into the BIOS setup screen and reconfigure the BIOS. To do that you need to press a key while the computer is booting. Usually F2 but can be other keys. It should tell you on the bottom of the first screen which key to press to enter BIOS setup.
If you don't know the settings the should be one for optimal defaults - use that one. You will also need to reset the time and date.
Save, Exit and re-boot and everything should then work.
During the boot process you will see on the screen a certain key to press to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
You will also need to set the time and date
In the main or system setup screen you should be able to see the date and time Using your arrow keys navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow keys or your page up / page down keys to change the date.
hope this helps you
Apr 14, 2012 | ASUS A8N-E Motherboard
CMOS error
Diagnosis: The BIOS ROM chip on the motherboard is probably faulty. It could also be another component on the motherboard.
You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent hardware or software change
If you don't know the settings you should be one for optimal defaults - use that one. You will also need to reset the time and date.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Dec 07, 2011 | Intel Desktop Board DH61WW Classic Series...
Bad check sum cmos
hope this helps you
Nov 18, 2011 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
My Laptop is Dellstudio15,When I swith on my laptop is showing error while booting it self is: Check date and time settings,System CMOS Checksum is Bad.Please help on this.
This error message means that its time for you to replace you CMOS battery.
CMOS battery is a small battery on the system board that provides power to the Complementary Metal Oxide Semiconductor (CMOS) chip, even while the computer is turned off. This chip contains information about the system configuration (e.g., hard disk type, floppy drive types, date and time, and the order in which the computer will look for bootable disks). The CMOS battery allows the CMOS to preserve these settings.
Hope this information willbe helpful. Thank you for using FIXYA.
Apr 13, 2011 | Computers & Internet
When i boot my system iam getting an error Check Date and Time settings and System CMOS Checksum Bad and Default configuration is used. F1 : Resume F2 :- Setup
Hi Good day!! That error maybe cause of your CMOS battery it may be not working, replace your CMOS Battery (2032 3volts), after you replace it with new one, set your date and time setting according in your time zone.
Oct 13, 2010 | Computers & Internet
IBM Thinkpad will not hold date & time.
Replace the backup battery and run BIOS Setup Utility to reset the time and date. This will resolve the issue.
Sep 15, 2009 | IBM ThinkPad T22 2647 Notebook
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
After 18 month the computer will not go into POST on a re-start but will start normally when completed turned off.
simple. clear the CMOS by using clear cmos jumper setting or remove the cmos battery and put it again and then change the bios settings as per ur machine configuration.
Feb 23, 2007 | Foxconn NF4UK8AA-8EKRS Motherboard
Computers & Internet Logo
118 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
