Question about Dryers
I have a Kenmore Elite he4 dryer that turns but I do not get heat. I have checked vents and circiuts and everything is okay. Any other ideas?
    President:
  • 1,554 Answers
I assume the heating element, high-limit thermostat, and the thermal cut-off are all good and you have electrical knowledge as you have stated that you have checked the circuit and everything is okay. You can bypass the high-limit thermostat and the thermal cut-off on the blower housing if you are in doubt about their condition. Simply disconnect the wires of each component and tape them together or jump a wire between them.
Let's proceed with the troubleshooting. Start by checking and making sure the heating circuit is getting 240 VAC from the power outlet. Check for tripped breakers if there's no 240 VAC supply to the dryer. Proceed with the next troubleshooting if 240 VAC is confirmed.
Remove the screws from the rear flange of the dryer’s top cover then lift the rear of the top cover and slide it back so the tabs clear the catches on the bracket, and then remove the cover from the unit. The top cover screws have nylon flat washers and make sure to use these screws when you reinstall the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover.
Remove the screws securing the machine control electronics board bracket on the left hand side of the dryer cabinet and pull the bracket away from the side of the dryer to access the connectors.
Disconnect the wires from the heater relay terminals on the machine control electronics board then tape them together or jump a wire between them.
Reinstall the machine control electronics board bracket back in place and the top cover then plug and start the dryer. The machine control electronics board is malfunctioning if the dryer heats up. Otherwise the centrifugal switch on the motor for the heating circuit is not working and needs to be replaced if the dryer still fails to heat up with the heater relay bypassed.
The machine control electronics board needs to be replaced if it is malfunctioning.
Posted on Sep 14, 2010
  • Jahn27
    Jahn27 Sep 14, 2010
    You
    don't
    have to accept or reject
    and rate this post
    to add information
    or post comments and follow-up questions should you need further
    assistance. But accepting a solution does not
    stop you from communicating
    with an expert. You may continue communicating with the expert as
    long as you need assistance regarding the issue stated herein.
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
Heating problem with kenmore elite he4 electric dryer. drum turns, lent trap clean, heating element ohms ok, thermo coupler ohms ok, thermostat ohms ok, timer counting down. still no heat.
limit switch stuck open should be behind motor housing is a tight fit to get to but there are two there on the element one on vent tube the other is thermal switch recommend chang the two on the tube ck element limits should all read continuityif not reolace
Jan 26, 2010 | Kenmore Elite HE4 Electric Dryer
Cloths not drying all the way
if you have heat and the clothes take to long to dry you need to clean out the dryer the lint duct and blow out the vent line,also go outside and make sure there isn't a cage or something acting like a lint catch stopping air from blowing out where the flapper is
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite dryer will turnover, produce heat, but will not dry clothes and after 70 min, lots of moisture in dryer
Sounds like the dryer is not venting. Check to see if the vent tube is kinked or the end is covered.
Sep 23, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer - heat but not drying
you have thermistor failure/ located inside machine reason for premature heat
Oct 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer does not dry clothes in one cycle
there are normally 2 at the back they are sold in pairs change both.
Jan 07, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
119 people viewed this question
Top Dryers Experts
