Question about Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh 1045 only one copy printed then error code sc 342 will seen
  • 903 Answers
Hi, there's no sc342 listed in the service manual, and I've never seen that code in years working on these machines. Are you sure it's not a different code, like sc542?
Posted on Sep 24, 2010
  • go into service mode and do a laser sync initialization 400dpi and 600dpi, this will solve your problem
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Ricoh 1045 error code sc 395
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Oct 07, 2012 | Ricoh Aficio 1045 Black and White Copier
May ricoh 1045 bao loi SC 329,mong cac chuyen gia giup do
this is laser unit code.press reset 107 hold the c key. press copy sp go in drum perform2109 400dpi initial setting and 600 dpi initial setting.
Aug 07, 2011 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 showing code SC545. First was SC 546 and now SC 545 can somebody help?
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
Jan 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh 1045 error code sc 672, 961
Controller to operation panel comucation error at start up.Check the controller stall,controller board installed correctly operation panel connectors.Enter im the service menu ,press the SP mode,open the front door,turn off the copier,unplugged the machine.Wait 10 seconds,plugged on the machine,close the front door,turn ON the copier and make a copy.
Dec 28, 2009 | Ricoh Aficio 1035 Copier
I HAVE AN ERROR SC 322 WHEN i GO TO PRINT RICOH 1035
Error Code SC322:
1st laser synchronization error
The 1st laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Possible Causes:
+ Poor I/F harness connection between the laser synchronization detector board and the LD unit.
+ Laser synchronization detector board out of position and angle of reflection not correct
+ Laser synchronization detector board defective LD unit defective
Not sure what your expertise is on this, but unless you know how to service the machine yourself, this one is going to require a service call...
There have been instances where toner drops onto the LD Unit and creates problems like this. About a month ago I replaced the Laser Synch. Detector Board in a 1045 for this exact problem and error code.
I'd start by cleaning up any toner on the LD unit, and re-seating all the electrical connectors on the laser unit. If that doesn't clear things up, it's probably one of two things, the LD Unit or the Synch. Board. I'd lean more towards the Synch. Board myself, but you never know...
Nov 18, 2009 | Ricoh Aficio 1035 Copier
Error code 350 error code 990 error code 540
Error code 990 indicates software problems yuo can check in SP7-403 for information.
Error code 540 will proberly indicate some heating trouble in the fix, you have to reset the machine with service code SP5-810.
Code 350 will disappear if you restart the copier.
Oct 09, 2009 | Ricoh Aficio 1035 Copier
A ricoh 1045 sc990 code says about Hard Drive problem. Where is this located? also please tell me what is and where is located a developer? Thanks in advance.
SC 990 is a software performance error.The software attemted to perform an unexpected operation.Software defective,internal parameter inncorrect or insufucient working memory.SC 990 occues when printing a message dtored in the information box.Avoid by firmware upgrade.This information can be cheked by using SP 7-403.The hard unit is located in rear right side up position of by pass.The developer is under toner botle in developer unit.
Aug 01, 2009 | Ricoh Office Equipment & Supplies
Service code SC546 on a Ricoh Aficio 1045
Try to go into service mode to reset the code...
Clear yellow botton
7
then press and hold the red stop botton till the display changes and then turn the main Power switch Off then back ON... You do not have to do any thing in service mode, just get to that display.... Don't change anything unless you know what you are doing. sc546 has to do with the fixing unit. You may be able to reset it.
Jun 03, 2008 | Computers & Internet
Ricoh Aficio 1027 All-In-One Laser Printer Logo
327 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
