Question about Amana Dishwashers
My Amana dishwasher which is an ADB1600AWS1 will go through it's cycles but will just not shut off. It keeps running and running. We have tried to reset but continues to run and run and run. Any thoughts?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If it won’t stop and keeps on running then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
Why does my amana dishwasher mold? In 43 yrs this has never happened
Spray TILEX mold and mildew cleaner inside and then run a cycle with no dishes, use hot water cycle.. Why could be the municipal water has a high concentration of mold spores for some unknown reason.
Jul 02, 2017 | Amana Dishwashers
My Amana dishwasher will start the cycle, but will run for a couple minutes, then cancel and drain....help!!
see the cause and fix it: God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Amana ADB1400AWB Dishwashers
My bosch shx46a05UC/14 will not shut off. I can open the door and the dishwasher just keeps going?
Are you please able to confirm what exactly is happening when you mention "dishwasher just keeps going".
Is it in a wash cycle and throwing the water around through the wash arms or do you just hear a pump running with water sitting in the base. Most likely there is a leak into the base and the auto stop circuit is trying to empty the dishwasher by running the drain pump. I would suggest you check the base of dishwasher for leaks.
Jan 28, 2011 | Bosch 24 in. SHX46A05UC Built-In...
Dishwasher will run through cycle but will not pump out water. Amana ADU7000D73WW
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 25, 2010 | Amana 24 in. ADU7000D Built-in Dishwasher
My Dishwasher starts as usual,,,fills with water then starts the wash cycle and quits after 5 seconds or so. it then does this 2 more times and shuts off completely. when i turn it on again it drains and...
Check the user guide manual. If resetting procedure is shown, follow it.
Otherwise the problem is with micro controller board. You have to contact the service provider as this is a computer program related fault.
If mechanical timer is used you can try cleaning them. But I doubt as the mechanical timers are no longer in use for the past few years.
Hope your incoming mains voltage is as per the recommendations!
110 V or 220 V as per your country standards.
Some times voltage fluctuations causes this problem. Should not be less than 10 % in any standard.
Sep 21, 2010 | Amana 24 in. ADB2200AW Built-In Dishwasher
Dryer runs but no heat
lean the exhaust vent tubes thoroughly and try again to heat up
a sensor in your dryer will shut down the heat if lint build up is present
Jun 07, 2010 | Amana NDE2330AY Electric Dryer
Amana dishwasher not cleaning
make sure water valve is good and you are getting hot water to your d/w run sink in kitchen to get water hot before running d/w
Oct 09, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
BOSCH DISHWASHER SHU33A DETERGENT DISPENSER WON'T POP OPEN
try some liquid detergent, somehow these powder and tablets tend to stick in and keep the door shut...
Sep 15, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
May 29, 2009 | Amana ADW662EA Built-in Dishwasher
Dishwashers Logo
173 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
