Question about Raymarine A65 Combo GPS Chartplotter/Fishfinder
Water temp way off. where is the temp thermister located to replace it
  • 3 Answers
Your water temp is measured by your transducer. There is a slight possibility that the transducer is OK and it is that the DSM25 is not relaying the TEMP info to the A65 display. Your best bet is to either try and find another DSM25 (friend or dealer) that you could try and plug in with your system. If the problem is still there, it is your transducer. If the problem goes away, then you would have to send in your DSM25 to the repair center to have it repaired. I believe the going rate for the DSM25 is $175 for a complete rebuild.
Posted on Jan 25, 2011
Clean corroded thermastat
What is a thermostat plunger?
If anything is corroded, Thermister or Temp Sensor, just replace them.
Nov 15, 2014 | Pentair Master Temp 400K BTU Natural Gas...
Maytag Dryer MED6600TQ0 F1 code
please follow this steps , use the multimer and fix it. Merry Christmas
The F1 code is a thermister error code. You need to use a meter and check the thermister, it is located on the blower housing. Just remove the lower panel to get at it. Unplug it and it should read around 10K ohms at room temp. If it is very low or does not read at all it needs to be replaced. If it is good you need to check the wiring from the thermister to the board to see if it is good. If it is and still displays the F1 code you need to replace the control board. That board is located on the left hand side of the unit when you have the top off you can see it on the left hand wall. Here is a link to the parts for your unit.
Dec 18, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Fridg temp control not regulating the temp in fridg
Refrigerators like the Hotpoint Model HSS25GFP have a air damper that controls fresh food sections temperature. Your refrigerator also has a diagnostics feature and can at times locate the problem causing the fresh food section to cool too much. Either your auto damper has frost blocking it open or the=> WR55X10025 Thermister is defective.
Try using a hair drier to force warm air into the damper to see if the damper will close better by melting any ice that may have the damper stuck open.Here is the=> WR09X10050 Damper Thermister Assembly Instructions on how to change this part can also be found on the same page HERE If you have any questions please ask, Thanks Sea Breeze
WR09X10050 Damper Thermister Assembly Below
3_21_2013_11_05_01_pm.jpgThanks Sea Breeze
Mar 21, 2013 | Hotpoint HSS25GFP Side by Side...
I have a whirlpool cabrio dryer model WED6600VWD. What does the F1 error code mean?
The F1 error code means that the thermister (cycling thermostat) has a open circuit and should be replaced.
To check the thermister you would need to DISCONNECT POWER TO THE DRYER remove the lower small front panel below the main one where the door is at and using a digital meter set to measure ya would remove the wires from the thermister and check for appx. 5,000- 7,500 ohms at room temperature.
If the ohms at within 5 thousand to 7thousand 5 hundred at room temp. the thermister is good and the control board is what the problem is....if the ohms is way lower or higher that 5-7,500 ohms the thermister is going to be what would need to be replaced.
Here is what the thermister looks like
I hope i have been able to help you fix your dryer,
GENE
Oct 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
We have an GE Profile @ 2005 side by side Model PSC 23 SGRCS5, SRRi L8411485. The freezer temperature has been fluctuating from -1 to 15 degrees. The icemaker is not working. We have replaced the...
The board could be bad, sounds like you have done the test by chilling then warming the thermister and see the rise/drop in ohms value depending whether the thermister is warmer or colder
Aug 17, 2011 | General Electric Refrigerators
Food is warm on top frozen on bottom in bottom in both refrigerator and freezer
My guess is the thermisters are out of spec and the control board is not getting correct temp reading from them. Use the PSS service manual to locate the thermisters and check them according to manufacturers specs listed in the manual.
This ADC link explains how the icebox functions
Aug 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Air condioner climbs to 86 degrees
These latest models rely on a cheap part called a thermister. Older ones used a mercury based cold control. A pc board sends a small amount of power through the thermister to judge the temp. As the temp changes the resistance inside the thermister changes. These el cheapo mexican thermisters are a dime a dozen. They have a quick connect. The thermister must be suspended near the coils but not directly on them or temps will not be judged correctly. Since a thermister is less than $10 bucks i would replace that first before calling someone.
Aug 21, 2009 | GE AJCQ08ACB Air Conditioner
Rinse cycle is not starting after wash cycle. I have to manually turn the knob and it won't start until just before the spin cycle.
inlet valves working correctly are you getting hot and cold water entering the tub ?start the machine and switch from hot to cold and make suire there is both temps available there is a thermister on some washers that read the temp of water cold is required for most machines to rinse ..the therms are mostly located on the inlet water valve inside the machine.
Aug 10, 2009 | Washing Machines
Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
Jun 08, 2009 | Sta Rite Sr200na - Max E Therm - Pool &...
Raymarine A65 Combo GPS Chartplotter/Fishfinder Logo
202 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
