Question about Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher
Maytag Dishwasher I would like to know the proper water level after DW fills. Older Whirlpool units a quick guide was when water just covered heater. I have a new D/W and the water supply is difficult to access, there is a kink in the water line slowing the water flow. The D/W fills to bottom of heater, but because the unit is so quiet I can't determine if it is timing out or working properly. I intend to repair water line when counter work is done. Thanks for any help Gary
  • 145 Answers
Newer Maytags should fill close or up to the heater not over. Sounds like your alright for now but I would get that water line fixed.
Posted on May 16, 2008
My dishwasher is not enough with water at the start of the cleaning cycle
My new DW had the same problem but when I had a tech come to the house he explained that the DW only uses .8 gallons of water and that what I am seeing is normal. Do your dishes come out clean? My did, so I guess he was right. Good Luck...xo
Sep 20, 2014 | Kenwood KDW243A Builtin Dishwasher
My dishes are not getting clean anymore! It's extremely frustrating. Also, sometimes my soap doesn't even dissolve! This dishwasher isn't very old, but I am tired of it!
hi, This is a water temp. problem. The first fill s/b about 125-140 degrees. You can try running your hot water tap for several minutes. Run a load, see if there is some improvement. Next, go to your water heater, see where the setting is. On a gas move dial up a notch. On electric remove top and bottom covers and do the same thing. You also need to clean the dw off and on. Take a gallon of white distilled vinegar and pour the whole gallon into the dw after it has started and run for awhile. Then open the door and let sit overnite, starting the next morning. Hope this helps.
Jan 17, 2011 | Whirlpool Dishwashers
Du1055xtsd2 whirlpool dishwasher runs but doesn't fill with water doesnt cycle
A few things could be wrong.
It can't cycle without water. be sure you have water at the valve under the dishwasher. You should be able to see it by dropping the front plate under the DW.
If you have water pressure, then check for voltage (120) at the valve with the timer calling for water. ( start of cycle).
If you have voltage and pressure, replace the valve.
If you don't have voltage, it could be the little switch inside the DW. It pulls up and down. The level switch could be bad.
If that doesn't do it, it may be the timer or the door lock interface.
Good luck.
Oct 13, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
My plumber just installed a new water supply line for my dishwasher. Now the pump comes on but no water fills up in the machine. If I fill the bottom of the unit with water, it works just fine. Even though...
You don't know how many times I've heard and found the shutoff valve off or partly turned off. Water entering DW is from line pressure not pumping. Items to suspect (again) the water supply valve (would'nt be the first time a new valve is bad). The supply valve (3374621) at the Dw, the float safety switch (normally at front left side,)...remove lower rack, lift float housing up and down. You should hear a click both ways and the housing should be free. Is the Dw fill valve getting control signal from timer. Should be 120v for about 60 sec.
Ric
Mar 10, 2010 | Whirlpool 24 in. DU915QW Built-in...
The first cycle water is not hot - all other cycles are hot - the water in the sink next to the dishwasher is not???
Where does the dishwasher connect to hot water? If it is connected to cold it must be changed. From your description, the water is coming from a long way off and has to warm the pipes as it travels to the dw. The dw should have a heater to bring the water up to temp after filling before it runs, if this heater is not working, the first run will be cold and the next hot because you have drawn enough water through the pipes to bring hot water to the dw.
1. Change where the dw gets hw.
2. Run hw in the sink before allowing the dw to start (if connected to same line).
3. Fix the dw's water heater.
Three possible fixes. Good luck.
Aug 27, 2009 | Maytag 24 in. DWU7402 Built-in Dishwasher
My Whirlpool Dishwasher, Model DU8950X, doesn't fill to the heating coil, only just above the pump. I have added water to the various cycles in order to get the dishes washed. I took everything in the...
f you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is sudsing too much. Cut back on the amount of detergent you use, and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Rate...me
Apr 21, 2009 | Whirlpool DU850SWPB
Water leaking onto the floor
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Jan 24, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Jun 29, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Unit never washes...
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be about 1/4 to 1/8 inch below the heating element. If not there..replace water inlet valve.
Jun 17, 2008 | Whirlpool 24 in. GU2548XTP Built-in...
Whirlpool Quiet GU2300XTLS2
Check water level:
Remove lower spray arm and rear water supply tube to upper spray arm. Remove torx screws that secure the sump cover. Remove the rounded cover on the left side to expose the chopper assembly. Inspect for breakage of blockage. There may be an additional plastic screen to remove first.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher Logo
113 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
