Question about Hotpoint RB525BC Electric Kitchen Range
Our Hotpoint RB525D all of the sudden wont turn on. It seems like it might be a power issue. Is there a fuse that might be blown?
First thing to do is to find your electrical panel box. You will have fuses or breakers. Locate the one that is associated with your range. If you have fuses it will be at least a 30 amp. If it is dark in the glass viewer, change it out with a new one. If you have breakers, find the correct one by the list that the installing electrician wrote on the inside of the panel box cover lid. Once located move the breaker switch to the right very firmly. Then flip the switch back to the left, you will hear a definate sound to indicate that you have switched the breaker on. If the switch stays in place and is not thrown back to the middle or right, go turn your oven on. If it threw the switch you have a short of some kind, I recommend calling an electrician or an appliance repairman at that point.
Posted on Feb 22, 2013
My hotpoint aquarius wmf560 won't turn on no power since I moved it from my old house yesterday any ideas ???
sounds like a blown fuse or broken wire
cut back the wire by 6 inch and rewire plug replace with 13 amp good fuse
Dec 17, 2015 | Hotpoint Washing Machines
My hotpoint bs73e wont heat up when i turn the dial
make sure the outlet has power first!!!!!!!!
check for a fuse, the fuse will be inside the unit right where the plug connect is located, you are going to have to remove some screws open the unit, check the wiring, check the element, if all okay call a service repair person or call the manufactures customer service line. look in the FAQ section for other issues
Sep 17, 2015 | Hotpoint Ovens
1999 Mazda millenia Electrical issues
the first thing to do is to remove the wires your sister conected, tape them seperately, these wires are power and ground wires and power the light in the visor mirror , they can not touch, so make sure they are apart and not touching any metal surface, tape them, one at a time.
there must be a blown fuse, did you check all the fuse boxes? there is one inside and one under the hood. start with this .
May 05, 2013 | 1999 Mazda Millenia
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
Power windows and power locks wont work
Check your fuses first. Then check for power at the switches, and power from the switches to the respective solenoid and motor. Most likely it's fuses. Also check where the wiring runs through the door into the car for bare spots in the wiring that might have blown the fuses.
Jan 21, 2010 | 2004 Mitsubishi Endeavor
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
My tv wont turn on
look at the fuse again if it is blown then it is a draw issue on the power board a dead short that over draws amps. a service center is needed to repair this issue
May 27, 2008 | Televison & Video
No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
Nov 26, 2006 | Hotpoint Aquarius WD640 Front Load...
Hotpoint RB525BC Electric Kitchen Range Logo
114 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
