Question about Whirlpool LGR7646E Dryer
Dryer no heat but runs
Whirlpool gas dryer lgr 7646eq2.
the dryer runs but there is no heat...what do i do?
  • 3 more comments
  • superjoey May 16, 2008
    also if its the ignitior is it tough to get to?
  • dalejr May 26, 2008
    whirlpool gas dryer lgr 7646eq2.
  • Anonymous Aug 24, 2008
    I have the some problem . please e-mail fangcharles88@yahoo.com to solve my problem
  • Anonymous Mar 15, 2014
    Dryer not heating
  • Anonymous Mar 29, 2014
    Dryer runs but doesn't heat
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
dryer no heat but runs - small_8_19.jpg For a detailed Dryer illustration, click below.
Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Versiondryer no heat but runs - redarrow.gifredarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrdryer no heat but runs - redarrow.gifs= Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
My clothes smell bad!
My clothes are marked or torn
DON'T FORGET TO RATE:
Posted on Aug 22, 2008
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
I have a 12 yr old dryer, model lgr 5636 eq2, it won't heat up.
could be the element or the fuse on the element box. Check also to be sure there is 220 volts entering the dryer with an ohmmeter...
Jan 17, 2011 | Whirlpool Dryers
I don't know anything about dryers so please bear with me. My dryer drum turns, fan blows, but wont heat. replaced heating element. Still no heat. Has 124 volts on both prongs of element. What should i do?...
Have you tried flipping the breakers @ your electrical box? Mine will do that at time when one breaker has tripped. It will have enough juice to run it but not heat it. IF that doesn't work there may be a broken wire to the heating element or possibly even a faulty heating element. I'd try the breakers first though.(Im not a professional I've just been a single mom for 18 years and have found myself working on all sorts of things and gaining knowledge from hands on experience) Hope it helps & works.
Aug 03, 2010 | Whirlpool Dryers
Whirlpool dryer model #LGR 8620 pwo runs but only heats sometimes.
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 14, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer not heating up
Check the following areas to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
If all the above check out ok, replace the timer or, control board.
Jun 17, 2009 | Whirlpool Dryers
Dryer turns but no heat and knob doesn't move
Check the switch on the motor. It may have failed, or has a wire/terminal broken/disconnected. It is a multi-contact switch. both sections must click. Could also be mechanically loose on the motor and therefore just not getting fully activated.
Hope this is helpful.
Apr 04, 2009 | Whirlpool LGR5636L Gas Dryer
Glo plug/ignitor will not light
I went on other web sights and found some helpfull information that was able to direct me to locate the source of the problem.
Jan 29, 2009 | Whirlpool Dryers
Don't know if my dryer is gas or electric
the E in the model # means it is electric. It would start with LGR if it was gas.
Nov 20, 2008 | Whirlpool Dryers
Gas dryer with no heat
check the ignition might be a glo-bar element or a maintained high voltage spark module. once there is a pilot a flame rod or a millivolt generator opens the main valve for fire.
Sep 03, 2007 | Whirlpool LGR7646E Dryer
Dryers Logo
657 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
