Question about Vacuums
Last night as I was vacuuming, I noticed that the belt stop indicator light was on. I pulled out the hair that had gotten tangled around the brush in hopes of solving the problem. It didn't change things. I then unscrewed the entire bottom piece to take out the brush roller. I removed hair from the end piece of the brush roller and reattached the belt; however, I cannot figure out where the microchip is supposed to go so that I can reassemble the base piece by screwing it back together. It seems as though there is no logical place for the microchip to go that doesn't conflict with either a screw location or other obstacles.
  • 377 Answers
Not sure what you mean when you refer to a "microchip" but maybe it is a sensor that works with the belt. Anyway, if you Google the make and model number of your vacuum you can probably get an exploded view or owners manual that might indicate where the part goes that you are referring to. If you have a problem finding it, send a message back and I will assist you.
Posted on Sep 14, 2010
Doesnt pick up, burning smell. Checked filters all appear clear?
Sounds like belt is slipping. Check brush roll for lint/hair tangled around it.
Jul 07, 2015 | Vacuums
Rotation brush starts then stops
Hi, it's Jim from Crucial Vacuum!
Start by checking your unit's brushroll and clear it of any tangled hair strands or debris that my be blocking the airway. Manually spin the brush after unplugging the vacuum. There may be something noticeably jamming it on the bottom of the unit. What make and model is the vacuum?
You can purchase direct your replacement belts and brushrolls from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC41&order=relevance&dir=desc
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim
Crucial Vacuum Customer Care
Oct 20, 2014 | Vacuums
Hoover vacuum cleaner - have suction in the hose, brush roller spins, but no suction when vacuuming carpet.
There is a clog or blockage in the channel near the roller or where the vacuum hinges at.
Unplug and turn it so that the bottom faces upward and use a screwdriver to open the bottom as you would to change belts. On most upright vacuums, it should only be two to four screws to remove the cover.
While the cover is removed, see if you can spot any noticable obstructions from there. While it is opened, it may also be a good idea to use a pick, screwdriver, or whatever may be handy to pull out any threads, strings or hair that could get tangled around the roller and brushes, to improve performance and last longer. In some cases or on some models, you may need to use a piece of wire or something, bent like a small hook, to reach up into the suction channels a bit to pull out any possible obstructions.
Also check along the path to see if there are other parts that you feel would be easy enough to open and clean out, but only so far as you feel confident in doing yourself, and be sure to not lose any screws and remember where they all go.
Oct 15, 2013 | Vacuums
Beater bar belt install
  • 1
    Unplug the vacuum cleaner and turn it upside down, flat on the floor, with the roller brush facing up.
  • 2
    Remove the the bottom cover plate from the vacuum by prying it off gently with a screwdriver blade. Set aside the cover plate.
  • 3
    If the old belt is broke, remove it by pulling the belt from underneath the roller bush. If the belt is not broken but simply worn out, and is still attached, cut it off with scissors.
  • 4
    Remove the roller brush by lifting both ends from the grooved slots in the housing of the vacuum cleaner.
  • 5
    Cut away hair, thread, string and other debris wound around the roller, using the scissors. Tangles on the roller brush are a common reason for belt wear and breakdowns due to the added weight and stress on the roller brush.
  • 6
    Slip the replacement belt over the roller brush and seat the belt in the groove in the center of the roller.
  • 7
    Slide the roller brush back into the grooved mounts on either side of the housing and snap into place.
  • 8
    Pull back on the new belt and slip the loop over the pulley attached to the vacuum motor.
  • 9
    Replace the bottom cover by snapping it back on the housing until it clicks into place.
  • Feb 16, 2011 | Hoover UH70015 Bagless Upright Cyclonic...
    My brush roller stopped spinning so I had to take it off and clean out all the hair that had gotten wound around it. I replaces it and now it is make a lound noise, but only when the brush is on. Could it...
    Could very well be the belt. When cleaning the brush it is a good idea to add some WD40 at the ends where the plastic pieces are that hold the brush in the vacuum. The brush needs to be able to move freely around the plastic pieces. Add the WD40 and rotate the plastic pieces around the brush until they move freely. Reassemble making sure the belt is put in correctly so the brush moves in the right direction.
    Please provide a Thumbs Up if this solution is of help to you. Paul
    Oct 10, 2010 | Bissell Upright Vacuum - The Pet Hair...
    The power head just stopped working last night and I can't get it to work on the carpet. What could be the problem?
    Did you try setting the power reset button on top? Mine wasn't picking up dirt very well so i took it apart thing the belt was slipping it wasn't. The nozzle was clogged up at the head. i pulled out all this cat hair to see one of the cat toys was lodged in. i used pliers to pull it out. if you have power and the brush is turning you might try checking that to make sure it's clear.
    Mar 29, 2010 | Kenmore 23313 Whispertone Bagged Canister...
    Every so often I get a smell of burning from my g4 Kirby vacuum. I noticed it's when I'm vacuuming a fairly new rug on this house I clean. Should I be concerned?
    If it is a smell of burning rubber - most likely your vacuum belt is overdue for replacement.
    At this point - remove the brush roller, remove the old belt, clean off your brush roller and remove any string or hair that may be bound up around it (usually around where the belt goes or on the sides), and put on a new belt. Your Kirby should act good as new if your bag is replaced at the same time.
    If the brush roller has too much string and hair wrapped around it, many times the brush roller will not spin as fast as the belt is driving it and you will get that burning smell.
    Dec 23, 2009 | Vacuums
    Dirt lifter power brush won't move
    most likely the small belt that turns the brush roller came off or broke, thi item can be purchased where you bought your unit. also, after you replace the belt, clean out tangled hair or strings that may have caused the belt to go.
    Aug 06, 2009 | Bissell 1699N ProHeat Clear View Force...
    Bissel Healthy Home vac brush/roller is jammed, cannot be rotated
    You'll need to take the bottom plate off, remove the roller, remove the belt, and pull out whatever may be clogging the rollers on the side of the brush/roller.
    Can you give us a model name for your vacuum? I can give you more details on how to remove the roller.
    Usually a pair of needle nose pliers can help with this.
    It happens when hair, carpet fibers, and other fun things get tied up and tangled around the sides.
    Best Wishes
    Nov 03, 2008 | Bissell Vacuums
    Dyson 07
    Start of by laying the machine on its back unfasten the solepate (which is the cover over the brush roll) as soon as its unfastened it will release with ease then you will see the brush roll with the belt around it simply pull the brushroll out of its position and release the belt from the motor spindal (if attached) and then out your new belts around the slot on the brush roll and feed the belt over the motor spindal (this will be very tough to strech on. Once you have done that out the brush roll back in its position and the soleplate back and you should have succesfully fitted a belt to your dyson.
    dont forget to rate this post........
    Aug 21, 2008 | Dyson DC08 Cylinder Bagless Canister...
    Vacuums Logo
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
