Question about RIM BlackBerry? Curve 8330 Cellular Phone
Ive got a Blackberry curve which i have had now for 12 months. Over the past week i can't scroll up, down, left or right whatsoever and it is driving me up the wall! Is there anything i can do myself to solve my problem? I would be grateful for your help and advice.
    Problem Solver:
  • 4 Answers
Fix Trackball
There are 3 solutions. Please consider them carefully and check with your vendor where you bought your BB in case either would cancel your warranty or insurance.
STEP 1
Remove the trackball yourself and replace it with a new trackball. The problem with this solution is if you break anything while attempting to fix it, you'll be worse off. If you are daring, I can find you a video link which you can watch online (on desktop or laptop) while you attempt the replacement.
STEP 2.
Take it to a licensed dealer you trust (maybe where you plan to purchase the trackball) and have them replace it for you.
STEP 3
Now, I know you said "do it yourself" but, it might be better to take it back to your vendor and have the BB replaced under warranty or insurance. Note that under either circumstance you do not get a new BB. They are refurbished BBs. They look like new but you risk getting one not as good as the one you have now. When they have to order you a replacement phone, you keep yours until it arrives and then make the switch.
MAKE SURE YOU DO YOUR OWN BACKUP OF YOUR BB BEFORE RETURNING IT.
Posted on Sep 20, 2010
I ive got a blackberry curve how do i save contacts from texts
If the number is included in the body of the text message, scroll down to the phone number and highlight it. Press the BlackBerry key, and select the option to Add to Contacts. If the number you wish to save was of the contact who sent the text, open the text, press the BlackBerry key and select the option to Add to Contacts.
Jan 27, 2011 | RIM Blackberry Curve 8520
My blackberry ball doesnt scroll down,just up,left and right ecept down
Chances are it's clogged with dirt and other debris. I suggest using a Q-tip© lightly dipped in rubbing alcohol and run it around the ball and move the ball and just clean it off. That should help.
If not, the ball probably needs to be replaced
Nov 17, 2010 | RIM Blackberry Curve 8300
How to clean up trackball for curve, cause it won't scroll down....only to the left and right...thx
everyone has the same problem with blackberry trackball. i wonder why the rim installed such a hardware in their phone. it makes a lot of trouble.
to fix it simply use a straw, no need ro replace or disassemble the blackberry, read more from the source http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Dec 07, 2009 | RIM BlackBerry Curve 8310 Smartphone
I cannot click using my trackball (AT&T Blackberry Curve 8310).I can scroll up and down but when i go to click on any applications, a menu comes up just as if the menu button to the left of the...
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 19, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
My scroll ball won't allow me to scroll DOWN; I can scroll up, across right and left, but NOT down................
pop the silver ring off from around the ball and remove the ball assembly. Be careful cause the ring only has connections on three sides and you must start on the side without the "pins". just keep messing with it and it will come out. then clean the rollers up and make sure the flap connector on the bottom is clean and intact. That should do ya for now and should hold you for several weeks
pls rate this fix
Oct 05, 2009 | RIM BlackBerry Curve 8310 Smartphone
Ball does not scroll down
the trackball roller pins need to be cleaned or the entire trackball replaced.
Jul 10, 2009 | AT&T Blackberry Curve 8300 Smartphone
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry curve scroll button sticking
I had a similar problem, and the only solution is to change the trackball which cost between $5 & $10 dollars on e-bay. An easy and cheap fix, it comes with the tool to replace the assembly. A kid can do the job
May 11, 2009 | RIM BlackBerry Curve 8310 Smartphone
Change ring tone on Verizon Blackberry Curve
Go to the "profiles" icon, select it and then scroll to the bottom to advanced. Scroll to where you keep your phone ringer volume to...loud or normal and hit the menu button to the left of trackball and select "edit", scroll down to phone, hit menu again and select edit. Scroll down to "Tune" then menu and select "Change Option"
Mar 06, 2009 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry? Curve 8330 Cellular Phone Logo
83 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
