Question about Pyle PLTDN71 Car Video Player
PYLE PLTDN71 CAR VIDEO PLAYER PROBLEM
CAN YOU PLEASE TELL ME IF YOUKNOW HOW TO GET THE IN DASH MONITOR UNSTUCK? SOMETIMES IT WORKS FINE AND THEN IT GETS STUCK
THANKS
  • brents_busy May 11, 2010
    Please explain "stuck" as in the screen wont retract or it wont come out? the cd is stuck. Please elaborate so i can help you
4 Suggested Answers
  • 5 Answers
SOURCE: WILL NOT TURN OFF!
yes. the probs you bought a pyle. lol. the speakers were good back in the days but the electronics really suck and thus you get prlike you do BUT it seems like your installation technician did something wrong. once you turn your car off the unit should shut off. its probably hooked up to a negative ground or wrong wire.take it elsewhere before your car burns.
Posted on Dec 24, 2007
djnick989
  • 1067 Answers
SOURCE: brake bypass
this is on a website link let me try to find it its a wire buddie had same issuue
Posted on Jan 27, 2008
SOURCE: I need to buy a Remote for a Pyle PLDVD65IN in dash cd player
i lost the face of my pyle plts76u i neet to buyit
Posted on May 21, 2009
  • 182 Answers
SOURCE: I have Pyle PLTDN71, everything is wired properly
u probably connected ur power or constant to ur lights. if ur lights turn on ur accesry switch and than ur ight if ur stereo turns off thanu have tosee witch wire is connected wrong
Posted on Jul 09, 2009
Pyle PLD70BT wiring to brake
I do believe u ground it or you can also google Pyle bypass codes and totally do away with the whole brake safety option
Feb 27, 2013 | Pyle PLTDN71 Car Video Player
Brake bypass
Jan 27, 2008 | Pyle PLTDN71 Car Video Player
Hi i installed the car video player, and it works good, until i turn on the car lights , then the car video player start to flicker and the screen gets bad, what can i do to fix it?
check that you haven't connected the power wire to the light power make sure its straight from the battery and straight from switchable power
pls rate
Aug 17, 2010 | Pyle PLTDN71 Car Video Player
I recently bought a PLTS72U power light no functions
check your ground power remote and parking switch
Apr 15, 2010 | Pyle PLTDN71 Car Video Player
Can some1 please tell me how to connect all the wires with my chvy wireing harness just to make sure im doing it right, because the unit doesn't turn on...
red-power(keyed), yellow-power(constant), black-ground. If you're having problems installing it, try powering it on with your'e car battery, if that works you have a blown fuse in the system.
Sep 05, 2009 | Pyle PLTDN71 Car Video Player
I have Pyle PLTDN71, everything is wired properly , but it only plays music for 3 secs and cuts off. The problem is repeated everytime the unit or car is restarted... anyone ???
Jul 09, 2009 | Pyle PLTDN71 Car Video Player
WILL NOT TURN OFF!
Dec 23, 2007 | Pyle PLTDN71 Car Video Player
Pyle PLTDN71 Car Video Player Logo
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
