Question about GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Oven was cooking on the oven setting, and suddenly quit working. No oven, no light, no clock. As if it lost all power, but there is still power at the outlet, and the breaker did not pop.
  • GE Master
  • 3,361 Answers
Most likely a blown fuse inside the MW. It will be on the control board or on the incoming power line inside the cabinet.
Posted on Sep 14, 2010
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Advantium display reads "nite"
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Feel free to contact me directly (see below) if you have other questions.- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Nov 30, 2017 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Advantium 120 model # SCA1001HSS03 has died and working. The circuit breakers is fine. The dedicated electrical line is working fine. There are no lights, no sign of life. The oven was working and at the...
Many microwave ovens have an internal fuse , but I was recently told by a dealer that any unit costing under 200.00 was not worth fixing .my fuse cost 3.15 from local home improvement store
Oct 19, 2017 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
I have a GE profile advantium 120 . The panel lights up I do not get an error code the timer works but it does not heat up. what could cause this
Check your power setting, making sure that you are cooking at 100%. Adjust if necessary.
It could also be a bad magnetron.
Regards, --W/D--
Jul 05, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
379 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
