SOURCE: Wanting an owners manual for 1981 Grumman Olson
for an owners manual try www.edmonds.com and for a repair manual try www.autozone.com or your local library
SOURCE: my car makes a scrapping and or grinding noise when driving and braking like i'm dragging something
Just by the information you put, I would say its your brakes. They are most likely worn out past the minimum wear (3mm). If its whenever you drive maybe you are dragging something? Your exhaust system supports may have failed, maybe something stuck in there and so you are dragging it along. Take a look underneath your car.
If the noise only happens when you brake then its gotta be a problem with your brakes. Sometimes rocks get stuck in between brake pads and rotors, this makes a very annoying squeeling sound until the rock comes loose and falls out. Another possibility, like I said earlier, is that your brake pads have worn out and is now metal on metal. I recommend you go to a shop and get your brakes checked. Brakes are a very important part of your vehicle, safety especially, so I don't recommend doing it yourself unless you know what you are doing.
Hope this helps.
Thanks
SOURCE: '96 Toyota 4-Runner makes a loud squealing noise and brake light
Sounds like one of the auxillary belts slipping it may just need tightening up. I think the 4-Runner has two belts one large and one for the steering pump
SOURCE: Noise from rear wheel area that sounds like bearing noise.
Might want to check your camber adjustments and look into shocks and struts. They could all be worn out but prolly the camber is off causing abnormal road noise and abnormal tire wear
SOURCE: Screeching noise coming from driver side tire
The high pitch sound may come from the brake pads as metal parts hit the disc to signal the owner that it needs change. The metal parts gets exposed when the pads have worn out. The brake also has a hub to cover the disc. See if the metal plate is hitting it but this issue would appear when the wheels are in motion. Check if it is the belts, have the tension checked out. Other than that the bearings are the other items on your wheel that could cause a high pitched sound when you car is in motion.
