Question about Plumbing
We have a Gould's J10S 115/230 well pump with a A.O. Smith C48A95A06 motor. When the pump sits for 24 hours and then we use it the pump shuts down. If we restart it the pump then runs fine. We have replaced holding tank and confirmed that the new tank air bladder was not stuck. We have replaced pressure gauge, cleaned tubes, replaced points........ I starts again after you hit it. Sometimes breaker trips so we replaced breaker and wiring. This pump whas worked fine for 10 years. One person lives in house with 1 shower w/o washer, dryer or dishwasher. Any ideas????
    Top Expert:
  • Plumbing Master
  • 15,427 Answers
Your replacing everything but the problem part which boils down to the pump its 10 yrs old and you havent tested it either bearings or winding failing in motor
Posted on Apr 25, 2017
3 Suggested Answers
SOURCE: ELECTRIC CONNECTIONS FOR AO SMITH ST1152
Went to a pool store. They wanted a week and $85 to "check it out" Then said they were
"almost" sure the two side by side posts were the correct ones. Since "almost sure" sounded better
than "not at all sure", I decided to go for it and hook it up that way. It would work or smoke the motor!
It worked!! Apparently the post next to the voltage selector is just a dummy or something.
I don't know why there was a screw in it but not in one of the two correct posts.
Posted on Apr 02, 2009
  • 126 Answers
SOURCE: I have a AO Smith motor model #C48A95A06 attached
Your axpansion tank is waterloged (well extrol)
Posted on May 17, 2010
How could I use my 1hp AO Smith C48A95A06 model motor Goulds pump using solar energy instead of grid power alone?
possible run inverter from batteries to convert to AC power make sure enough battery voltage and big enough inverter
Oct 28, 2017 | AO Smith Pool & Spa
How to replace impeller on guolds j10
What is the make and model of the "pump"?
Gould is a motor manufacturer.
The manufacturer of a pump, will use a third-party vendor like Gould, to provide them a motor for their pump. Gould is Century/Magnetek, which is now AO Smith.
BUT...
remove pump housing/volute covered, and access the impeller. Then on the back of the motor you should be able to access the shaft. Lock up the shaft so it does not spin, and then unthread the impeller. Some pumps, especially two speed pumps, will have a locking screw in the center of the impeller. That screw will be counter threaded or backwards thread. It keeps the impeller from spinning off the shaft during normal operation between high and low speeds.
again if we had more specific information, we would be able to assist you better.
Feb 09, 2015 | Pool & Spa
I'm wiring a 220v Gould Century 1081 pool motor does the pool motor need to be bonded in order to get a proper ground
bonding required for safety 1st hot to L1 2nd hot to L2 green to ground or case and bonding wire to lug on case
May 25, 2012 | AO Smith A O Smith Motors Century 1hp 115v...
How to manually reset an AO Smith 2 hp motor?
If you did not press a reset ( and even if you did) the motor is damaged and that is causing the circuit breaker to trip. You need to have the motor inspected to see if the damage is repairable or if you need a new motor. A local electric motor repair shop should be able to take care of that for you. The thermal overload has reset itself if after cooling down the motor is trying to start but trips the breaker.
To be certain it is the motor, disconnect the line leads and be sure they are insulated from ground and one another. Turn the breaker back on. It should stay closed which confirms it is the motor tripping it when connected.
If for some reason the breaker still trips, there is a problem with the electrical circuit feeding the pump.
Jul 26, 2009 | AO Smith A O Smith Motors A O Smith 2hp...
Gould Water pump Problem
sounds like cavitation in the pump due to the introduction of air. Check for leaks or cracks in the suction line so air isnt being induced into the pump.
Dec 19, 2008 | Plumbing
Plumbing Logo
613 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
