Question about Maytag Dishwashers
The spring came off the door. how do you put it back on it was on the side of the dishwasher.when you open it just flops down find the spring on the floor.do you have picture of where it goes
  • Maytag Master
  • 3,361 Answers
Remove the bottom toekick panel from the front of the dishwasher.
Look just inside and you will see spring mounting holes on the bottom support frame.
The spring goes from a hole to the hole in the lower door hinge.
If I had a model number I could be more specific.
Posted on Sep 14, 2010
The dishwasher door no longer has a return spring. It just flops down.
Bob, make,model# and order spring and replace, not hard to do.
Check that your spring, just did not pop off first.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 24, 2016 | Dishwashers
Miele dishwasher door not working properly
Try contacting Miele with the model & serial number of your appliance they will send you out a new spring.
they are in scoresby from memory fern tree gully rd.
Mar 29, 2014 | Miele Dishwashers
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
I opened teh door and thought i felt something hit
Murray, It sounds like one of the door springs has broken and that is why the door seems heavier and opens with much more force.
You'll want to at least make a temporary repair and order a new replacment spring to get your dishwasher working like it should and so it's safer too.
You can check to see which side of the dishwasher the spring broke, by locking the door shut (with the cycle set to "off"). Now remove the lower access panel, beneath the main dishwasher door. There are a couple of screws near the top corner edges of the panel, just under the main door and a couple more on the toe kick near the very bottom.
Once you've got the lower access panel off, you'll be able to see the two door springs, (there is one on each side). Of course, the broken one might have fallen off the spring notches, so look around and you should see it.
With the door still closed and locked, you can remove the broken spring and see if it's just the hook end that broke. If that's the case, you can reform the end hook using a couple pairs of pliers and reinstall the spring on the door and frame mounting points. You'll have to use pliers to stretch the spring slightly to get it on the other mounting point, once you've got one end on a mounting point. If the spring broke off more than 3 coils, you'll need to replace it with a new one.
You can find a replacement by using searspartsdirect.com and putting in your model number to locate a line drawing and parts listing for your particular model. You can also order a new one from them, or use the part number to get one locally, if you wish.
Once you've got the spring back on the door and cabinet mount points, you can unlock the door and gently lower the door to see if everything is working properly. Once you've opened and closed the door several times, you can reinstall the lower access panel and you're back in business.
I hope you find this Very Helpful and best regards!
Oct 24, 2009 | KitchenAid Dishwashers
Soap dispencer not opening. Feels like spring broke
Should be easy to check the spring. When the door is open does the dispenser door spring back? If not it may just be that the spring has come loose. Disconnect the power. Most dishwashers have screws down the door sides to remove the front panel. Gently remove it and check the spring hasn't just come off the dispenser
Oct 03, 2009 | Dishwashers
The door flops open as the rope has broken. I have the replacement part but need a diagram to show how to replace the part. Where can i find the diagram?
Documented in the manual...The plastic part goes on the metal hinge on the door...follow the rope down to the top wheel (clockwise and around) to the bottom wheel (counterclockwise and around), attach to the spring.
Apr 12, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
Feb 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Frigidaire Dishwasher
yeppers..and get her another trampoline(have a 5 year old, meself.)
Jun 03, 2008 | Frigidaire FDB658RA Built-in Dishwasher
Dishwashers Logo
93 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
