Question about JVC PC-XC20 Shelf System
When I put a Cd in and press the button to play the 3 of the dics shows in the window for a second or two and the a series of 00000's shows and nothing happens.
  • JVC Master
  • 17,129 Answers
Possible that the CD tray is out of alignment .So the processor is intiating the mechanism to load but an error in the drive circuit is not allowing the mechanism to change the mode.
So you will need to check this out and if so set the timing right.
Posted on Sep 14, 2010
I just bought a used 2002 Pontiac Aztec the dic is in french how do I change the language to English
The Driver Information Center (DIC) displays PONTIAC or BUICK for 3 seconds and then the most recently used key fob when it first powers up. The DIC returns to the last display status after displaying the key fob number. The DIC can be displayed in English or French. In order to change between English/French press and hold the Mode button for more than 3 seconds .
There are 2 buttons on the DIC.
  1. Set button
  2. MODE button
Set Button
The Set button allows options to be reset in the DIC. Options can be reset by depressing and holding the Set button for 3 seconds
Feb 12, 2016 | Pontiac Cars & Trucks
Tip
Cadillac service light 1989-01
Eldorado
2000-01
Turn the ignition to ON. Press the TRIP button on the driver information center (DIC) switch to view various menu choices and stop on OIL LIFE REMAINING. A message will display the percentage of oil life remaining. Press and hold the RESET button on the DIC switch for at least 2 seconds. A message will display the percentage of oil life remaining as 99 percent. The engine oil life monitor is now reset. Turn the ignition OFF.
DeVille,
Eldorado
1999
To reset the service Oil Life Indicator, display the
"OIL LIFE LEFT" message by pressing the "INFORMATION SKIP" (skip info) button. Press and hold the "RESET NO" (no info reset) button until "100% OIL LIFE" is displayed.
Deville,
Seville
2000-01
Turn the ignition to ON, Press the INFO button on the driver information center (DIC) to display ENGINE OIL LIFE. Press and hold the INFO RESET button on the DIC until the display reads 100% ENGINE OIL LIFE. The engine oil life index is now reset. Turn the ignition OFF.
Deville,
Seville,
Eldorado
1997-98
Display "ENGINE OIL LIFE" by pressing the "INFO" button. Press and hold the "INFO RESET" button until the message shows 100.
All Models
except
Fleetwood
1994-97
Press the "INFORMATION" button until "OIL LIFE LEFT" is displayed. Press the "RESET" button until "100" or "0.0 OIL LIFE LEFT" is displayed.
Fleetwood
1994-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds.
All Models,
Seville,
Eldorado
1993,
1994-95,
1994-95
The automatic transaxle message can be reset through the following procedure. If "CHANGE TRANSAXLE FLUID" appears on the Information Center, press and hold the "OFF" and "REAR DEFROST" buttons until "TRANS FLUID RESET" appears.
DeVille,
Fleetwood
1991-93
When "CHANGE OIL SOON" light is illuminated, press and hold the "RESET" and "RANGE" buttons on the Fuel Data Center for 5 to 60 seconds. When the buttons are released, the light will flash four times if it has been reset. If the light comes back on for more than 5 seconds, repeat the procedure.
Allante
1989-93
When "CHANGE OIL SOON" appears on the Driver Information Center, press the "RANGE" button until "OIL LIFE INDEX" shows on display. Then press and hold "AVG SPEED" and "RESET" (or "RANGE" on late models) buttons until display shows "100".
Seville,
Eldorado
1992-93
Press "INFORMATION" button on the Driver Information Center until "OIL LIFE INDEX" is displayed. Press "STORE/RECALL" until "OIL LIFE INDEX" resets to 100.
Seville,
Eldorado
1989-91
When "CHANGE OIL SOON" or "CHANGE ENGINE OIL SOON" appears on the Driver Information Center, press "ENG-DATA" button until the "OIL LIFE INDEX" appears. Then press the "ENG-DATA" button and the "RANGE" buttons at the same time until 100 displays (about 5 seconds).
on Dec 07, 2009 | Cadillac Eldorado Cars & Trucks
I JUST CHANGED THE OIL ON MY 2006 COBALT AND THE READ OUT STILL SHOWS 25% ,MY QUESTION IS HOW DO I RESET THIS .THANKS
Try this and if it does not work let me know.
1. Turn the ignition key to the "Run" position but do not start the engine.
2. Press the display button until the display reads "Oil Life"
3. Press the accelerator (gas) pedal all the way down and all the way back up 3 times within 5 seconds.
4. The oil life index should reset to 100 or the display will read "Oil Life Index Resetting", and when completed then turn off the ignition.
Start the vehicle and verify that the oil life has been reset, and if it did not reset then repeat the procedure, because sometimes it will take more than one try to clear and reset the oil life index.
If that does not work then try this procedure...
1. Press the fuel information button until ENGINE OIL LIFE appears on the Driver Information Center (DIC).
2. Press and hold the select button.
3. The engine oil life percentage will return to 100.
4. Turn the key to OFF.
5. If the CHANGE ENGINE OIL message comes back on when you start your vehicle, the engine oil life system has not reset.
Repeat the procedure.
Sep 26, 2010 | 2006 Chevrolet Cobalt
After changing oil in a 2007 hhr, how do you reset the oil life
Turn Ignition to RUN
Press "Information" and "Reset" buttons at the same time on the DIC to enter personalization menu.
Press " Information" button to scroll through avalable options.
until DIC desplay shows OIL-LIFE RESET
Press and hold "RESET" button ubtill DIC display shows " ACKNOWLEDGED"
This will tell you that the oil life has been reset.
turn key to " LOCK"
Sep 13, 2010 | 2006 Chevrolet HHR
Calibrating compass
Yes you can.What you have to do is press the mode button on the driver info center(DIC).Press and hold the set button for 3 seconds.The DIC will display the zone.This is what part of the country you live in.What state your in.I don`t know what Zone your in so I don`t know if it is in the correct zone or not.They go from i-15.This will determine how accurate your compass will be.If you press set it will change the zones.If it is the correct zone then press the mode set button til the DIC displays calibrate compass.Press set and the DIC will tell you to drive in circles.Find a large empty parking lot to do this.I just crank the steering wheel and keep going in circles.The DIC will say calibrating.When the compass shows direction and temperature it is done calibrating and you can stop driving in circles.Hope this helps.Good luck.If you need to know what Zone your in Just post back with the state you live in and I can tell you the zone.
Mar 29, 2010 | 2002 Buick Rendezvous
No second install disk!!
If you put in the Brood War expansion cd, the installation will resume. Apparently that's the 2nd disc. It also shows up as SCDisc 2 under computer in the start menu.
Jul 25, 2009 | Blizzard Entertainment StarCraft Battle...
DIC doesn't work
Are you talking about the one in the roof console, near the windshield?
With the key OFF:
Depress and hold the MODE and the ENGLISH/METRIC buttons.
With these two buttons still depressed, turn the ignition switch to the RUN position.
When you do this all display segments will light for 2 seconds then off for 2 seconds, then it should show "PS" then turn off. After this, then unit may show E1, E2, E3 or E4. If E and a number (E1) didn't come up, then there are no errors in the System.
Turn the van off, then....to set the compass, find your location on the map picture. The number you fall under is your zone number.
Turn the ignition ON.
Cycle the driver information center (DIC) to the Compass/Temperature mode.
Press both the E/M and the MODE buttons for approximately 5 seconds.
The last entered variance zone number will be displayed.
Press the E/M button until the proper variance number (See picture) is showing.
Press the MODE button in order to set the new variance zone and resume normal operation.
Note: The features are controlled by outside data. The only feature that is self contained in the unit is the compass, and if it is not working correctly, then the unit is malfunctioning and I would suggest replacing it with a new one.
Perform these steps on more time. If it still does not work right, then the unit will need to be replaced.
Press both the E/M and the MODE buttons for at least 10 seconds until the calibration symbol appears.
Release both buttons once the calibration symbol appears.
Complete 3 360° turns in an area free from large metal objects.
But I would wait before replacing it. Drive it around normal for a day first. If it nothing happens then, then replace it. The compass will not always calibrate right away.
Good luck and hope this helps.
May 09, 2009 | 1999 Chevrolet Venture
Tire pressure reset will not reset
Labatche822,
The process for resetting your Tire Pressure Monitor (TPM) is below.
Good luck, let me know.
Regards.
To reset (calibrate) the system:
1. Turn the ignition switch to RUN.
2. Press the GAGE INFO button on the DIC until
TIRE PRESSURE appears on the display.
3. Press and hold the DIC RESET button for about five
seconds. After five seconds, the display will show
TIRE PRESSURE RESET. If TIRE PRESSURE
RESET does not appear on the display after about
five seconds, see your dealer for service. After you
release the DIC RESET button, TIRE PRESSURE
NORMAL will appear on the display.
The system completes the calibration process during
driving. During the first 10 to 25 miles (15 to 40 km) of
driving, the system will not alert you if a tire is high or
low. After 25 to 100 miles (40 to 160 km), the
system will only alert you about pressure differences of
12 psi (85 kPa) or more. After about 100 miles (160 km)
of driving, the system will alert you if one tire is
10 psi (69 kPa) different from the other three tires.
May 04, 2009 | 1999 Buick Park Avenue
Dic
To make it play, you normally just push the play button.
If that does not work, often that means you have a lens problem.
Use a dvd lens cleaner kit , like the ones that you see clicking here.
If that does not work, you will need to take apart the unit, access the lens pickup, and clean the lens directly, using isopropyl alcohol and a cotton sticks.
Oct 10, 2008 | NAD L40 CD Player
114 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
