Question about Homelite ZR10580 FactoryReconditioned 42cc 18" Gas Chain Saw
What is the gas/oil mixture on a UT104554 Chainsaw
dontbother10
  • 2220 Answers
SOURCE: What is the gas/oil mixture for a Homelite Z3300
I cannot find a manual and it is not listed at Chain Saw Collectors Corner http://www.acresinternet.com/cscc.nsf. I did find IPLs and judging from them she is no youngster, based on that I am going to say the manual recommends 32:1 (1 gallon of premium fuel to 4 ounces of quality 2-cycle oil).
If properly adjusted up it will start easier, plugs and the exhaust will take much longer to carbon foul on 50:1 (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
dontbother10
  • 2220 Answers
SOURCE: chainsaw gas mixture ratio
An XL from that time frame recommends 32:1 here:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/d4b1071a456ca76c88256cd6001cc24c?OpenDocument
If my saw it would be adjusted for and operate on 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
Lou
Posted on Apr 03, 2010
  • 4088 Answers
SOURCE: gas oil mixture
The header says that it is an electric saw which would only require bar oil. A 2-stroke gas engine, however, does require fuel mixed with a modern saw oil at 40:1 ratio plus bar/chain oil in it's own tank as well. Always premix the fuel and oil in a separate can and shake well even before filling the saw. Hope this helps!
Posted on May 24, 2010
  • 3 Answers
SOURCE: Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
Posted on May 26, 2010
  • 420 Answers
SOURCE: Gas / oil mixture ratio on 16
Most 2 cycle engines like 50-60 to 1 ratio
Posted on Jun 02, 2010
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Gas and oil mixture
Stihl saws run a 50:1 mixture of gas to a high quality 2 cycle oil designed for small engines, not outboards and snowmobiles.
Mar 07, 2014 | Stihl Service Manual for 030AV, 031AV...
I have poulan woodshark 38cc chainsaw. i need to know if it is a gas/oil mixture and if so what is the mixture
I would say yes. Most are and I would get a small bottle of two cycle oil and mix it to one gallon of gas. Most hardware stores sell the oil.
Aug 06, 2011 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
Can i use any 2 stroke oil
An electric chainsaw does not require 2 stroke oil. This oil is only used for gas/oil mixtures for gas powered chainsaw. Chain oil should be used (or even transmission oil) to lubricate the chain.
Aug 20, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas oil mixture
May 24, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Chainsaw gas mixture ratio
Lou
Mar 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Gas Oil Mixture
Fuel Mix: Add 6 oz. McCulloch custom lubricant or 1 PT. S.A.E. 40 (16:1) to 2 U.S. Gal. Regular Gas
Aug 25, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Homelite ZR10580 FactoryReconditioned 42cc 18" Gas Chain Saw Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
