Question about Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE Error Code F50
I've been working on my washer for a few weeks now with little progress. 1st I had a F51 error code. I found the RPS sensor burnt up and two of the wires in the harness mashed (one brown one blue) with wire exposed. Replaced the RPS and taped up the wires. The motor works on agitate however it will not spin on slow (23RPMs) unless I start it by hand. I've replaced the motor with a new one but I have the same problem. Any suggestions?
  • Anonymous Mar 27, 2014
    I get an F50 code and I have replaced the PC main board twice? What does this code mean? Is it the RPS (rotor position sensor)?
  • 117 Answers
Can be motor speed control board
Posted on May 15, 2008
I am working on a Kenmore Oasis washer, model
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#@
Jun 29, 2010 | Kenmore 24032\24036 Top Load Washer
Leaking and F51 error code on my Kemore Elite Oasis Washer
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer.
Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis washer model # 110.2703 shows code F-50
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 25, 2010 | Kenmore Oasis 27042 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis F51 code - already replaced RPS. Now what?
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit. This can be caused by several different problems. Make sure that you are not overloading the washer. Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily. If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board. A failed RPS sensor or a failed control board could also cause this problem.
Sep 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore, Elite Oasis washing machine, apprx. 2 yrs. old has display code F-50 with continuous beep. Technician unable to come out for 1 week. Any ideas?
problem with the RPS(rotory positon sensor)sensor.wait for the manufacturer for repair.make suer the washers not in use as it might lead to F51 error code.
Dec 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Ellite Oasis - model #27042603
Jun 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error Code F50
You are not going to believe this but I had the feared F-51 code on my machine and after doing a ton of electrical troubleshooting and part replacement........the problem was a pair of Boxers jammed in between the walls of the drums!!!!!! REMEMBER.....
LOOK FOR THE SIMPLE THINGS FIRST!!!!!! DONT MAKE A MOUNTAIN OUT OF A MOLE HILL!!!!!
Catriver is gonna love this one!!!
Dec 05, 2007 | Kenmore Oasis 27042 Top Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
146 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
