Question about Lexmark E120 Laser Printer
My lexmark e120 printer prints with horizontal lines across the pages, how do I get rid of this?
Many times horizontal lines -- esp if constant (e.g. 4 inches apart) appear-- on laser printers indicates a drum issue. NOT usually inexpensive. Sometimes one can dis-assemble part of printer and clean drum with soft cloth and therefore "buy some time"
Posted on Sep 14, 2010
HORIZONTAL LINES ACROSS T644 PRINTER AND 930.00 ERROR CODE
The error code 930.00 indicates a problem in the laser print head section of the printer. This will cause error in the printouts like you are having. This type of problem is not user serviceable and will require an authorized service dealer to obtain and install the printhead assembly. This is directly from page 2-24 of the service manual.
Jul 24, 2012 | Lexmark T644 Laser Printer
Lexmark e120 prints text with black printed all over the page
Please click on the link http://bit.ly/rkP361 to see instructions on howto go about the procedure. For additional assistance,please contact Lexmark Technical Support.
Feb 24, 2011 | Lexmark E120 Laser Printer
I have a thin white line on every page when i print fron my new lexmark x543xl....any ideas
Is it a vertical line (as the paper traces its path through the printer)
or a horizontal line (across the page) ?
> from my new Lexmark
If it really is "new", then take it back, and exercise the warranty to get it repaired/replaced at _no_ cost to you.
Aug 17, 2010 | Office Equipment & Supplies
E120 Laser Printer: my Lexmark e120 printer doesn't printing at all, n...
You may need to replace your photoconductor unit. Part number 12026XW
May 17, 2010 | Lexmark E120 Laser Printer
How can I get rid of horizontal blue lines? I have lexmark 5150 ''three in one'' printer. Every time I print horizontal blue lines appear across the paper. Please help.
Hello. Your cartridge, probably, just needs cleaning. Remove the cartridges from the printer. Take a warm, damp paper
towel. Set one ink cartridge on
the paper towel like how it is
placed in the printer - nozzles
facing down. Drag the cartridge
lightly across the paper towel in
one direction (left to right)
until the bottom of the cartridge
looks clean. Do the same thing to
the other cartridge. Place them back in the printer. If problem persists, try to check this link to the Lexmark website. http://bit.ly/a8KP8M . It gives you another way of cleaning the cartridge nozzles. Hope these resolves the problem. Good luck!
Mar 17, 2010 | Lexmark X5150 All-In-One InkJet Printer
Can't print in color
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Bold lines on Fax and Scan
May 26, 2009 | Lexmark X7550 InkJet Printer
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printing mostly blue with lines across page
I have the same problem that you are haveing, I changed the ink ,both black and color, and it hasen't helped any, I wanted to get a new copy and printer machine but I don't want to get one and have the same problem. I have runined a lot of print paper trying something else new. I am open to all suggestons. thanks Ken.
Dec 03, 2006 | Lexmark X73 All-In-One InkJet Printer
Lexmark E120 Laser Printer Logo
792 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
