Question about Microsoft Xbox 360 Console
Single red light & system error on screen - Microsoft Xbox 360 Console
  • 4,102 Answers
Hi, let me know what the error code is on the screen then i can tell you what the code relates to and also how to go about solving the problem.
most single red lights refer to the hard drive being at fault so try removing the hard drive and then switch it on and see if you get the same error code, if you do then it has probably over heated but ill tell you more when you let me know the code your getting on the screen
Posted on Sep 14, 2010
Red light 5times
You do have a Asian model of TV, the 5-Blink error code is the T-CON module problem, it may be a single board (you may look at the board number & find one on EBay), or built-in the LCD panel (You need to replace a whole LCD panel that will be too expensive)
Apr 06, 2015 | Sony KLV32EX330 32" Multi-System LCD TV
My xbox 360 console is having a problem. when i turned it on this morning it said there was an error. ONe light was flashing and it was red. my friend was talking to me about this before and he said it was...
The single red light is not the "ring of death" error. The "ring of death" error would give you 3 red lights. The single red light could mean many different things. Are you getting any kind of error code on the screen when you turn the xbox on? My suggestion would be to unplug everything from the power, remove the hard drive and wait a few minutes. After, plug the power back in (leave the hard drive out) and attempt to power it back on and see if the error reoccurs. If you get an error, check for error messages on the screen and post them here. Unfortunately with most Xbox errors you will need to send it to Microsoft for repair. How old is the Xbox?
Jun 28, 2011 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Turn the console on, displays the xbox screen then screen goes off and a red light starts flashing on console, says system error
is this a single red light? if so, it is a E code error. if there are 2, it is a overheating problem. if its 3, it is a general system error which could be a number of things which you need to figure out the secondary error code to narrow down the problem.
to find the secondary error code:
1. after the red lights start flashing, hold down the "controller sync" button.
2. push the "eject" button 4 times and count the amount of red lights that flash. the red lights will begin to flash rapidly. secondary error codes are only 4 numbers. 1 light = 1, 2 lights = 2, 3 lights = 3 and 4 lights = 4.
after you get the code go to this website, and on the right hand side of the screen under "Xbox Repair Guide" select your PRIMARY error code (1,2,3 or 4 slow flashing red lights). then it will ask you to enter your SECONDARY error code, which is the one you discovered in the steps above.
this will give you a very narrowed down idea of what is wrong with your console, and will give us "questions answerers" a better idea on how to help ya out!
Jan 01, 2011 | Microsoft Xbox 360 Console
Three red rings on xbox360
  Can u pronounce good English? Read along: woof, roof, loof, shoof, shoof, woof,  loof, poof, woof, woof, hoof, loof, roof, shoof,
  Test results: U r a good dog. Now stop barking.
Oct 02, 2009 | Microsoft Video Game Consoles & Games
My Xbox says system error contact support with a single red light and on screen error of E74
Let the truth be knowen
99.98% system errors are directly caused by the high
operating temperatures G.P.U. thermal expansion of
the chip it will literley de solders itself from the main board.
I have found the only reliable prosses that I use is to straighten the
P.C. board if needed then re-flow the G.P.U. back to
the pads on the main P.C. board this works . And they stay fixed
Rob
Sep 01, 2009 | Microsoft Xbox 360 Console
Xbox F73 Fault
E73: I/O Hardware Error - Couldn't calibrate HSIO Bus from edram: this error is likely caused by a problem with the Ethernet port or supporting control devices
Jul 12, 2009 | Microsoft Xbox 360 Console
Single red light flashing
Needs 3 red light repair. You can contact us at xbox360fixer@verizon.net
THanks
Jan 03, 2009 | Microsoft Xbox 360 Console
Xbox 360
no error number ?
May 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
18 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
