Question about SanDisk Sansa Clip MP3 Player
My sansa clip will not turn on. When I connect it to my computer it shows it to be charging.
  • scolby42 Sep 14, 2010
    How do I do a factory reset on my sansa clip
    President:
  • 1,566 Answers
Did you try to have it charged for a few hours? Also please try to do a factory reset. But this will delete all files on the player and it will reset it into factory defaults.
Posted on Sep 14, 2010
My Red Sansa Clip 4GB will not show on any computer i plug it into, It only charges and i have tried the auto detect, mtp, and msc settings. Any Suggestions?
See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> http://support.microsoft.com/kb/939211. Run the hotfix.
Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
Instructions to connect in Forced MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/61
Instructions to switch player to MSC mode are listed here: http://kb.sandisk.com/app/answers/detail/a_id/207
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware
NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit
May 17, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip on turn on
can u more specific? u mean how to turn on your sansa clip or your clip can't turn on?
if the first one:
u may can see the instructions.
if the second one:
SOLUTION 1 - Reset the player.
SOLUTION 2
- Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, then connect it to the PC.
3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.
5. Verify if you can turn on the player.
6. Reset the player if necessary.
Feb 25, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa clip mp3 player doesn't get detected
Trying:
1. Update Windows Media Player 11 for computer
2. Get in Device Manager, right click on icon device and anable it.
Good luck
Jan 22, 2010 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sandisk Sansa Clip 2GB not detected by XP SP2
Change the USB Mode to auto-detect and see if you get better results. If that fails, switch entirely to MTP mode.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
