Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune electric dryer makes very loud screeching noises when you start it, could this be a belt??
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Sep 14, 2010
My maytag neptune dryer mdg5500aww is making a screeching sound. It is drying the clothes but it is getting louder by the day. What part needs to be replaced?
There are 2 wheels in the rear that the drum rotates on - one could be binding. The tensioner has a wheel, check it for rotation. Belt slipping? Check motor for operation - check that plastic blower isn't rubbing in its box. Dryers are easy to disassemble - check YouTube for procedure.
Jul 24, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
The dryer is making a loud noise as it tumbles.
you need to open it most of the dryer need maintanace every 4-5 yars and if you keep runing it you may do more damage.
there are several parts that the drum is turning on them and they get bad after few years. like felts,riders,belt...
Apr 30, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Makes screeching noise when on
The roller that keeps the belt tight around the drum has a worn bearing. It is frozen so it will not move causing the screeching noise you have. Replace the belt as well as the whole belt tensioner. It will come complete with a new roller & bearing
Feb 11, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer makes a loud noise when running. It still works and drys. Its a loud screeching sound. Do you think the belt needs to be replaced?
Could be the one of the 4 drum rollers, Idler pulley or belt.
I usually replace them all at once for long term reliability.
Jan 08, 2010 | LG DLE3777 Electric Dryer
Makes loud screeching noises when in use
If you have a front loading machine,
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your rollers for flat spots, if they have flat spots on them replace them.
If the rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loud screeching noise at times when in use!
Normally loud screeching noises come from the drum rollers being dry.
They need lubricant, or replacement
Sep 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag sde3606ayw make loud screeching noise
You Need to replace the drum Rollers. They cost around 10.00 Each online, 20.00 Each at your Dealer. Please Dont try to Put Oil on The Roller Shaft. It will come off and make its Way To Your Clothing. Martin Appliance Sells Specific Oil for the shaft for around 8.00. Thanks Sean
Dec 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
374 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
