Question about Magic Chef CYE4000AWW Electric Dryer
Makes a noise when drying. Stops when you move it
  • Magic Chef Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical consol with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Sep 14, 2010
When I start the mower it makes a dry grinding noise on the brake,but if I touch the brake pedal and move it about 1 inch the noise stops?
The brake is not fully disengaging and is still contacting the drum. When you play with the pedal you are resetting it.
Check the linkages involved, clean and grease them and also look for bent parts.
Sep 06, 2015 | Cars & Trucks
Whining sound
check the oil level
Jun 21, 2014 | John Deere Garden
I have a stackable washer/dryer gas maytag. Purchased around 17 years ago. The dryer is not drying clothes. Gas is powered fine and it is heating up. The cycle seems shorter than normal
The problem with it not drying is most likely going to be a worn out blower wheel thats slipping and not moving the warm air through the clothes to dry them properly. Always a pretty good sign the blower is slipping is,if you hear a rumble noise from the dryer at start up and also that same rumbling noise when the power stops. So if you hear it at start up...wait 30 seconds and open the door and listen for the rumble noise as drum stops. also you can check where the vent exits the house and see if their is air flow when the dryer is running.
GENE
Aug 19, 2011 | Maytag LSE7806A Top Load Stacked...
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Noise coming from a/c pump
Your front bearing for your pully is getting ready to go out,I hope this help you, you will need a new compressior
Sep 10, 2009 | 2000 Pontiac Grand Am GT
2001 Olds Bravada noise from rear axle when driving
you may be low on gear oil...have someone check it for you before the rear end locks up
Feb 03, 2009 | 2001 Oldsmobile Bravada
Humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Jan 29, 2009 | Whirlpool LER5636P Electric Dryer
Magic Chef CYE4000AWW Electric Dryer Logo
48 people viewed this question
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Roderick Scott
Roderick Scott
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
