Question about Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312
Would like to know if laying a feezer onit side would harm the freezer in any way Paul
  • Kenmore Master
  • 3,740 Answers
Hi Paul. Welcome to FixYa I am Kelly. Here is the straight scoop on laying any unit with a compressor down horizontally. When you do that the oil in the compressor flows into the coolant lines. There is a small risk of having the drier clog but if you are careful your will probably have no problems at all. The key is that after you stand it back up is to wait 30 minutes minimum before plugging it in. If you do not wait for all of the oil to gravity drain back into the compressor it can cause your freezer to run but never cool should the drier clog up with oil.
Just make sure you do the long wait after it is righted / moved and everything should be ok.
Kelly
Posted on Sep 14, 2010
  • 394 Answers
As long as the freezer is not plugged in while on it's side and after you put it right side up you wait an hour to let all the compressor oil drain back to normal nothing bad can happen.
    Scholar:
  • 63 Answers
Also, if you look at the compressor you'll see one side has a tube coming from it that is cut and sealed, you'll also see a small (thin) line on the same side. This is the high pressure line and the cut line is the tube that was used to process the system. Lay the freezer on the side that allows these tubes to be on the bottom. This way the oil will only go into the condensor and when you stand it upright again the oil will drain down back into the compressor if you give it time (advise you leave it for at least an hour or longer if you can). If it's put onto the evaporator side the oil can fill up the evaporator and may not all come back down to the compressor.
Posted on Dec 26, 2011
Can this freezer be laid on it's side or back to transport? Thank you.
Lay down a shipping blanket or an old blanket and transport the freezer on it's back.
Aug 07, 2015 | Freezers
How do you recharge the feon in a chest feezer?
Well you could get a tap valve, like a bpv-31 and tap into the low side, which is the bigger line coming out of the compressor, but your going to need some freon guages, not ones for automotive, but for a/c or refridgeration, freon, and a recovery pump.; just these parts and tools alone your paying more than what it be to have someone over.
Jun 05, 2012 | Freezers
A church member donated a freezer to our church, I had to lay in down to transport it. I plugged it in , the light came on but after five days it did not cool ,one bit. Did harm the unit by laying it down?
You pluged it back in after you laid it doun. You needed to let it stand back up to let the freon to get to the condencer. You can try to unplug it for 2 days now to see if the freon will go back down or you might need to have it serviced now.
Good Luck
Aug 14, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
Red alarm light came on after we defrosted a westinghouse freestyle vertical freezer. what ius causing this pls. wilf
red alarm light is telling you that the feezer is too hot
(above 18c)it should go out when powered up and back to normal temp.
Mar 24, 2010 | Freezers
I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Mar 07, 2010 | Freezers
Feezer will not stay at zero goes up to 30 I think defrost cyle not working right
Replace defrost timer in refrig cabinet. Located in the light and control area on top of refrig side. Remove cover, there will be a box with wires and a little wheel that is the timer.
Feb 22, 2010 | Kenmore Freezers
Freezer won't get cold
oil is in the cap tube .due to the laying it down . and maybe in the evap . it may never work properly again . let is sit for a week then start it up in a warm area. wish you luck ..m m
Nov 20, 2009 | Freezers
I am moving and need to lay my upright freezer down for the 6 -8 drive. will it harm it?
No it will not harm it. you will just need to stand it up for 24 hrs befor you plug it back in. That way all the fluideds go back to the bottom the way it should be.
Good luck and please rate
Sep 16, 2009 | GE 203 cu. ft. General Electric Upright...
Should the sides of feezer get warm
depends on the freezer manufacturer. Some are built with the condenser coils inside the sides of the unit. Some have heaters around the door openings to prevent frost build up and sweating (condensation).
If unit works, keeps temp. and there are no issues, leave it alone.
Aug 09, 2009 | Frigidaire Freezers
Moving a freezer
Shouldn't be a problem in itself, but it's prudent to let the freezer stand the right way up for an hour or two before you turn it back on.
Nov 28, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
272 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
