Question about Alpine Car Audio & Video
Hello, i need to know which colour wire is the constant live, because everytime i switch off my car it resets
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Constant is yellow.
Posted on Sep 14, 2010
Which wire is my memory wire.everytim e I turn my car off I have to go back in the setting to change my bass and Trimble
What brand & model is the player?
Usually the yellow wire needs to go to constant live and the red to ignition live (or at least that is how Sony are!)
Nov 06, 2016 | Car Audio & Video
Reverse light wire under the dash
The reverse light wire will not be under the dash, there will be a constant live feed from the fuse to the reverse light switch on the gearbox, that is no good for you. You need to take a power after the switch, that's live when reverse is selected. You may be able to pick this wire up from the loom, loom runs down the left hand side of the vehicle. Look at the wire colour to the reverse light at the rear and trace in the loom. at the front kick panel
Jan 26, 2014 | 2001 Nissan Pathfinder
I need to know which colour wires are the power supply on a nissan almera 1999 ambition radio harness
Normally,orange needs to be hooked to a constant 12V source straight from the battery(called constant).This will keep your presets and time running when the car is off,which is also normal.Red is hooked to a wire which gets it's power from the ignition being on,also called switched power.
Good luck,Greg
Nov 03, 2010 | Car Audio & Video
My yellow cable is wired up yet still loses memory is it the yellow that should be constant live on the harness? but what colour is the origional constant live that conects to yellow?
If its losing memory swap the red and yellow over, some cars are red switched and yellow permenant, some are the other way, if you swap the two 12v feeds it will sort the problem.
Oct 23, 2010 | Pioneer DEH-P7400 CD Player
Panasonic car cd player, need to know what colour the live and nutral wires are for the cq-c1311nw model thank you
red is ignition or switched positive power, yellow is constant power, black is ground.
Oct 13, 2010 | Panasonic Car Audio & Video
I need a stero wireing diagram for my nissan pulsar 1995 hatch back telling me witch colours are for what speaker etc
Hello!
POWER
Switched+12 (ACC)= Blue
Constant +12 (Memory)= Pink
Illumination (Control)= Red/Yellow
" (Switch)= Red/Blue
SPEAKERS
FR+ Brown
FR- White
FL+ Purple
FL- Green/Yellow
RL+ Black/Pink
RL- Orange
RR+ Gray
RR- Gray/Red
Guru..............Saailer
Jun 04, 2010 | Car Audio & Video
Colour codes for 83 corona, wiring stereo the colours are grey/black grey/red Brown Purple/green Grey Blue/yellow blue white/black any help would be great thanks!
Hello! I'm having a hard time reading your colors...So, I'll give you the 1983 Corona wiring...
POWER
Constant +12= Blue/Yellow Switched +12= Gray
Ground= Brown Antenna= Black/Red
Illumination= Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru...........Saailer
May 30, 2010 | Pioneer AVH-P5700DVD Car DVD Player
Hello!
POWER
Constant +12=Blue/Yellow...Switched +12=Gray
Ground=Brown...Illumination=Green
SPEAKERS
FR+ Light Green
FR- Blue
FL+ Pink
FL- Purple
RR+ Red
RR- White
RL+ Black
RL- Yellow
Guru............Saailer
May 28, 2010 | Car Audio & Video
Wiring/connecting wire from fan to home ceiling
this depends on where you live UK/USA et,c or other.
It is best to search the manufacturers site, to find installation codes/colours.
i.e USA use a lot Of Black and white. UK uses Red/Black Green/yellow.
And on houses that are rewired to 17th edition electrics ( UK ) the colours have now changed on mains twin and earth household Wiring. What Used to Be Red ( Live ) Is Now Brown. Black ( Nuetral ) Is now Blue. green/yellow is earth.
*** Important Note:- you should have several reds in a ceiling junction box or light fitting, these are circuit wires. ( Live From Light to next light ) The same as with Black ( Nuetral )
There will usually be 1 switch wire/Cable. this feeds a live from the switch, to the live power up to the light. many homes use a twin core and earth, from the light switch to the fitting. this may be black ( if a black/red ) has been used. *** Do not connect a black Switch wire with the remaining neutrals***
This will blow a fuse or trip a breaker.
Your solution:- connect the black neutral To the Black neutral cables ( more Than 1 at the ceiling Rose/fitting ) if there is a green/yellow or green ( this will be earth ) You may have 2 remaining Colours Possibly red and Blue or other. The Red Should be the switched Live. ( the single cable Red/Black with red tape around It ) This will be the switched Live. The remaining cable would probably be connected to the Bunch of Reds ( Constant Live ) As ceiling fans require a constant and switched live ( if the fan has lighting )
If in any doubt, consult a qualified or competant Electrician. *****And always remove or isolate the mains supply before attempting any installation*****. After the wiring is complete replace the fuse or switch on the breaker, to test your installation.
This information, is supplied by a fully competant electrician.
Thankyou for using fixya.
Mike @ Compurepair.
Jun 15, 2009 | Hampton Bay 24002 Ceiling Fan
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Car Audio & Video Logo
18 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
