Question about Dremel 395 Variable Speed Multipro Rotary Tool Kit
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
  • 3 Answers
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Posted on Sep 26, 2010
How to install a multipurpose cutting kit on a dremel
You will have to remove the plastic cap on the end of the tool where the tips go in. Then screw on the cutting guide.
Aug 27, 2014 | Dremel Variable - Speed Multipro Rotary...
Need to replace DE bearing dremel model 398
go to Http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
Mar 16, 2013 | Dremel 395 Variable Speed Multipro Rotary...
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
Nov 06, 2012 | Dremel Variable - Speed Multipro Rotary...
Need a Flex coupling. part #529430970 for model 395
http://www.dremel.com/en-us/AttachmentsAndAccessories/Pages/Attachments.aspx
Oct 31, 2010 | Dremel 395 Variable Speed Multipro Rotary...
How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
Apr 17, 2010 | Dremel Variable - Speed Multipro Rotary...
Takes an adapter to screw onto the nose of the Dremel. The shaft itself is gripped by the correct size collet tightened as you would any bit.
Mar 02, 2010 | Dremel 225 Multipro Flex - Shaft...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
Mar 30, 2009 | Dremel Variable - Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel 395 Variable Speed Multipro Rotary Tool Kit Logo
179 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
