Question about Panasonic PT-52LCX66 Projection Television
NO SOUND OR PICTURE AND POWER SUPPLY IS OK - Panasonic PT-52LCX66 Projection Television
    Sergeant:
  • 171 Answers
This could be a few things, don't really have much info to work with but I can tell you this much this TV is a rear projection and they have a projection lamp they are made to last 6000-8000 life hours witch is a average time of 2-4 years old so depending on how old your lamp is this could be the issue,if you have a new lamp and its is not working then the problem will be coming from your ballast board but to be honest I don't think that is the case
I found the lamp you need for this model
http://www.discount-merchant.com/SearchResults.asp?Search=TY-LA1001
Posted on Sep 14, 2010
Vizio 19 inch no picture no sound
That capacitor could possibly be the cause. On some sets, the 12V supplies both the video and audio circuits. I would recommend replacing the cap and checking power supply outputs especially the 12vdc supply.
Sep 09, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
42 inch philips lcd no picture no sound
Sometime a no picture, no sound still has the power light or some other led blinking. The blinks might be an error code that will isolate the problem.
In general on LCD TVs with no picture, no sound, no blink code, the main power supply has failed. The capacitors weaken and when bad enough, damage the power supply.
If there is a blink code, the most, if not all of the power supply is OK and the blink code could point to the problem.
Jan 19, 2011 | Philips 42PFL7422D 42 in. LCD TV
Tv sound but no picture
The backlight inveter board may have gone out ,or the power supply is not working to supply power to the inverter board, those are the two places to look.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 08, 2009 | Televison & Video
DS204D-S26 No Picture Soundis OK
check the power supply proper voltage supply
Sep 21, 2008 | Sova Digital DS205-S32 Television
TOSHIBA IC DATA DISGRAM NO IS 8873CSCNG6PR6
EHT OK BUT NOT FUCTION NOLIGHT AND NO SOUND NO DISPLY
Jun 18, 2008 | Televison & Video
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
I get no picture on samsung pck5315r TV
no picture & sound ok as sound is there means your power supply &high voltage section is ok problem is in video section 1 crt is glowing or not if not check its supply. 2 check crt base or any connector for loose 3 check supply to video & crt base(g2) 4 check for video signal is coming to video sectuon from processor ic. 5 loose print if any. hope this will help
Sep 30, 2007 | Samsung PCK5315RX TV
No picture
as sound is ok means power supply is ok. 1 check for filament if it is glowing means it is ok otherwise check for its supply. 2 check video and crt pins voltages 3 check for connector loose 4 luminance section in chroma ic. good luck
Sep 18, 2007 | Sony KV-27V10 27" TV
Zenith big screen
sound is ok means power supply is ok. as there is no picture there is a problem in video or luminance section. 1 check chroma ic supply 2 check signal line to video section 3 loose contact in video section 4 crt base loose 5 crt supply 6 no supply to g2 7loose contact in brighness line
Sep 16, 2007 | Televison & Video
Panasonic PT-52LCX66 Projection Television Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
