Question about HP 20s Calculator
How to reset hp20s - HP 20s Calculator
  • 193 Answers
Resetting the calculator using the keyboard To halt the calculator and reset the keyboard, follow the procedure below:
  1. Press and hold the [C] key.
  2. Press and hold the third key from the left on the top row.
  3. Release both keys at the same time.
  4. The calculator will now display "0.00" (if the number of decimal places is set to two.)
To completely reset the calculator and erase all user memory, follow the procedure below:
  2. Press and hold the first key from the left (the N key) and the first key from the right (the sigma +) on the top row. Release all three keys at the same time.
  3. You should see "ALL CLr" on the display.
  4. Pressing the [C] key will clear the message.
  5. The calculator will display "0.00."
Posted on Dec 20, 2010
  • mariacris728 May 02, 2011
    is still impossible to turn it off. Do not accept the normal comand . We use the both procedures above but no refresh still apperas 0.0000
    : and the picture of a battery
    We already change the batteries and problem still continua.
    Please help us . Our e-mail is mariacristina.sanchez@cytec.com Thanks
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
How d i set hp20s calc to c places
Press left-shift FIX then the number of digits.
Apr 30, 2014 | Corporate Express CEB95005 Calculator
Heat pump manual
ek weet nie jou hond
Dec 19, 2013 | Pool & Spa
I want 5.1 surroud sound from a panasonic home cinema system model number sc-ht1500 through a blue ray disc player bd-hp20s what audio leads do i need
TOSLINK (optical cable). do not forget to set audio output in the setup menu of the BDHP20 and select optical as an input on scht1500.
Nov 22, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Hp20s has locked up
If the calculator has locked up you should perform a reset.
  1. Press and hold the [C] (ON/OFF) key
  2. Press and hold the [LN] key (third key from the left on the top row).
  3. Release both keys simultaneously. T
  4. The calculator should display "0.00" (if the number of decimal places is set to two.)
If that does not bring it to life you should perform a full memory reset
  1. Press and hold the [C] (ON/OFF) key.
  2. Press and hold the first key from the left ( the Square root x key) and the first key from the right (the SIGMA+ key ) on the top row.
  3. Release all three keys at the same time.
  4. Calculator should display "ALL CLr".
  5. To clear the message press the [C] (ON/OFF).
  6. The calculator should display "0.00."
If the calculator does not respond as expected,
  • Remove the batteries, and
  • with a metallic coin (and what coin is not metallica) short-circuit the calculator's electrical terminals.
  • Maintain the coin for about ten seconds.
  • Replace the batteries (preferably fresh ones) respecting the diagram inside battery compartment.
  • The Calculator should display "ALL CLr".
  • To clear the message press the [C] (ON/OFF).
  • The calculator should display "0.00."
If the calculator does not respond to the foregoing procedures, remove the batteries and leave them out of the calculator for 24 to 48 hours to drain capacitors.
If it continues to malfunction, it will need to be repaired. One repair shop in Pennsylvania, USA has a website at http://www.fixthatcalc.com. You should contact them.
Hope it helps.
Thank you for rating the solution.
Nov 05, 2009 | HP 20s Calculator
My decimal point is now a comma, how do I change it back to a point? I have an hp 11c calculator.
Look for a key or a Left Shift, Right Shift accessed key that has ./,. Might be with the 0 key. (Sorry I have an HP20s .)
Hope it helps.
Sep 23, 2009 | HP Office Equipment & Supplies
Won't play a new blu-ray video
I bought a Sharp BD-HP20S and got Stargate Continuum to play on it, only problem was it wouldn't.
Had bad pixilation, jumping picture and stuttering sound.
Went onto Sharp's website and followed the instructions for downloading and burning a firmware update cd (or usb stick).
Made an update cd, put it in and within 5 minutes the update was over.
Result?
Prefect picture and sound.
Really simple and easy to do.
If you don't want to make a cd yourself Sharp will send one out to you if you contact them.
Nov 28, 2008 | Sharp BDHP20U Blu-Ray Player
Reset
The P300 has 3 kinds of reset mechanisms, 1. Soft Reset: you can keep all DRAM data. Procedure: Push the Reset button 2. Hard Reset/Save SDRAM -- Use hard reset/save SDRAM mode to reset the MobilePro P300 without losing the data in SDRAM. Use this mode if the safe software reset mode doesn't improve system operation. Procedure: Reset Button and Power Buttons at the same time. 3. Hard Reset/ Clear SDRAM: You will lose all data. Use to reset the MobilePro P300 and delete the contents of SDRAM. Use this mode to reset the MobilePro P300 to its factory defaults. This is also referred to as a hard reset/clear SDRAM. **Caution** This procedure will delete all user installed applications and user data. If necessary, back up your data before performing the hard reset. Procedure: Push the Reset, Power, and Record Buttons at the same time
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
HP 20s Calculator Logo
852 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
