Question about HP Laserjet M2727nf Multifunction Printer
My HP M2727nfs prints blank pages. Even demo page / reports are blank. NO errors on display. Paper gets warm, so fuser works. New cartridge doesn't help. Neither cold reset. What can this be?
  • ict8527 Sep 30, 2010
    I did this two weeks ago and it didn't work for me. Last week I returned the printer to my HP supplier. When I get feedback about the problem I'll post it. Thanks Al.
    Pim
I did all what is needed but still printing blank pages in hp lj m2727. for tha blank copies i dont think it involves the formatter board, then it should print engine test.try replace power board.
RONALD ONGOL
Posted on Nov 17, 2011
  • 223 Answers
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Posted on Sep 30, 2010
    I did this two weeks ago. It didn't help for me. Last week I returned the printer to my HP supplier. When I get any feedback about the problem I'll post it. Thanks a lot Al.
    Pim
  • Al Toledo Oct 05, 2010
    If the pages are blank it is def the formatter board, both the 1522 and the 2727 have a known issue with the formatter board.
    Al
HP CP1515n Toner tray stuck on right side
you should check transfer belt or fuser unit.
Aug 24, 2016 | HP LaserJet CP1515n Printer
PAPER FEEDS INTO PRINTER BUT COMES OUT BLANK
HP DeskJet f4280 Spitting Out Blank Paper. - HP Support ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Solved: I can hear it printing, but the paper is blank when it's finished. ... Mark as New; Bookmark; Subscribe; Subscribe to RSS Feed · Highlight · Print · Report ... green checks say every thing is good to go, but the test print comes out blank,. ... Reinstall the cartridges into the product, and then gently close the cartridge door.
my printer is printing blank pages, and i just changed ink
Nov 18, 2015 | Office Equipment & Supplies
Because its possible to be more then one answer. Here is a direct link to the step by step process to self diagnose the possible solution.
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01626559
Jan 31, 2015 | HP Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
HP 4550 Color Laser jet reports no "errors" yet does not print
HP 4550 Color Laserjet Printer - Blank or white pages :
01. Your software application is sending an extra page-eject command.
02. Check the software’s printing configuration information. There is a problem with the network configuration.
03. Some sharing devices on networks may generate a blank page as a separator.
04. Check with the network administrator.
05. The printer may be feeding two or more pages at once because the paper is difficult to separate.
06. The sealing tape has been left in the toner cartridge.
07. The toner cartridge is empty or defective.
08. The laser scanner door does not open properly.
09. Remove and reseat the toner cartridge.
10. Check the laser scanner shutter door for proper operation.
11. The toner cartridge guide is damaged,
improperly positioned, or missing.
12. There is no transfer roller voltage.
13. Perform the Half Self-Test Functional Check to check all other electrophotographic processes.
14. Replace the transfer roller if necessary.
15. The high-voltage connectors are mounted on the high-voltage power supply (HVPS) PCA and protrude into the toner cartridge cavity.
16. Check the springs for functionality. Clean if dirty; replace if defective or missing.
The HVPS PCA is defective.
17.The DC controller PCA is defecti  There is no drum ground path.
18 Check the drum ground.
19. The laser scanner cable assembly is defective
20 The page length and margins are not set correctly for the paper size. Verify that the ribbon connector at J1307 of the HVPS is
properly seated.
21. If the HVPS has been removed recently, verify that the ribbon connector from the DC controller PCA to the HVPS is properly
seated at both ends..
22. Verify that the photoconductive drum is rotating properly. Perform is the drum diagnostic test to visually observe if the drum is rotating.
23. OR using a felt-tipped marker place an index mark on the edge of the drum outside the image area. Turn on the printer (wait for
drum rotation to occur), and then look to see if the drum has
24. moved. If the drum has not moved, investigate the mechanical
and electrical drum rotation circuitry and movement mechanisms.
25. The imaging drum shutter may not be retracting. Replace the imaging drum.
26. Lst but not the least, please fry to have the Printer int the Setcie
27. Use only HP Authorized Genuine catridges only
Jul 21, 2009 | HP Color LaserJet 4550 Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Left side of page prints blank
Hi there in the paper handling menu check the paper size settings as it maybe as simple as the incorrect paper size has been set in the machine
Hope this works for you
Thanks J
Dec 12, 2007 | HP LaserJet 2820 Printer
HP LASERJET 4PLUS PRINTER-PRINT OUT BLANK PAPER AND WITH ERROR MSG 41.3
Get a new printer.
Serious if it is happening repeatedly and it is not because of corrupt data like a bad file being sent to it, then tis biga buckas any way you go, replacing the laser or the Main Control Board. From your description it will be laser, laser units wear out because inside is a little motor working real hard and eventually they wear out or main board the brains behind the operation has lost the plot
here is the code description from manual
41.X Printer Error
A temporary printing error has occurred. The page containing the error will automatically be reprinted. If the error persists:
1. Reseat the connections to the laser scanner and then to the engine controller board.
2. Replace the laser scanner.
3. Replace the engine controller board.
Nov 20, 2007 | HP LaserJet 4 plus Printer
HP Laserjet M2727nf Multifunction Printer Logo
1,403 people viewed this question
Seeker5211
Seeker5211
