Cannot print since installing windows 7 - Computers & Internet
  • 480 Answers
Hi, It would be advisable to update the drivers of your printer to be compatible with Windows 7. You can check and search the model and the drivers using the model name of your printer.
Thank you for choosing Fixya.com for resolving your issue
Posted on Sep 14, 2010
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
Jul 22, 2011 | Broderbund The Print Shop Deluxe Version...
Installing Print Shop 21 in Windows 7
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
Mar 14, 2011 | Broderbund The Print Shop 21 Deluxe Full...
For key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install...
1. instal server utility on Windows 7
2. right click icon choose properties
3. select compatibility tab choose your o/s
now run it and presto......
regards, dean
Jan 08, 2011 | Keyspan USB Server US-4A (d47710) Print...
HP Deskjet F4480 will not print after vista to windows 7 upgrade. Ran HP printer diagnostic tool says driver conflict, uninstalled re-installed same problem, same diagnositics. Attempted to print test...
Windows 7 comes with basic driver built into the operating system (in-OS driver). With this basic driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot. When you connect the product to the computer, Windows 7 detects the hardware and automatically installs the correct driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD. Follow these steps to install the basic driver in Windows 7.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Your basic Windows 7 driver is now installed. Some functions might not be available, but you can use the following workaround procedures instead.
For more options go to LINK .
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 17, 2010 | HP Office Equipment & Supplies
I have window 7 64bit and the keyspan software installed fine but the server utility does not recognize the print server. I allowed port 3842 tcp and udp through the windows firewall but still no luck.
for key span server to work with windows 7 install windows xp mode to windows 7 ( this can be downloaded from microsoft website if you have windows 7 pro and above. if you have windows 7 home then install windows virtual pc, start it up and insert a windows xp pro install disk. for info on this google 'workaround to install windows xp mode in windows 7 home premium and home basic') Once you have windows xp mode running, install the keyspan server utility int he virtual machine and setup as usuall. then share the printer. go to windows 7 devices and printers and add a printer, chose a network printer, select the new virtual machine and select the shared printer. In order for the printer to work just start up the keyspan program from windows 7 and print....your welcome.
Sep 08, 2010 | Keyspan USB Server US-4A (d47710) Print...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
May 27, 2010 | Dell 725 InkJet Printer
I have HP 2015dn printer. In Windows XP I can print duplex automatically. In Windows 7, when I installed the printer, it uses the default driver from Windows. When I tried to print duplex, it printed the...
No there isn't that's the biggest problem with Win 7. DRIVERS.. if they aren't expressly written for Win 7. Then it is all just one big headache. In saying that sometimes installing as Admin, & in XP SP2 Compatibility Mode, helps.
Feb 03, 2010 | HP LaserJet P2015 Printer
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
