Question about Ao Safety PELTOR ALERT M2RX7A Radio
Good bateris, no sound! - Ao Safety PELTOR ALERT M2RX7A Radio
1997grand cherokee inline 6 cyl.good batery & alt. what's causing it not to charge batery ?
make sure all connections are clean and free of battery corrosion is the battery "really"good it might need more water in it they run out sometimes always check the ground areas make sure they are clean and touching bare metal
Mar 15, 2013 | 1997 Jeep Grand Cherokee
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
I have a 2003 Galant GTZ 3.0L . batery is good and all the lights work. when I try to start the car all I hear is single click. the car does not start. I cleaned the batery cables and still the same, no...
if you've tested your battery and know you have a good connection at the terminals that one click sound is a bad starter. you may wish to attempt to tap on it while cranking to try to get it to start. if you do crawl under your car use jack stands to hold the car in the air. never leave a losd on the jack. safety first. if this was helpful please leave positive rating.
Nov 30, 2010 | 2003 Mitsubishi Galant
Hi ive a 18v bosch striker cordless drill seems to stop when heldon left side sometimes goes better when i tape the lithium batery to stop looseness can you help is it triger , brushes , or loose...
Well it sounds like you solved it yourself. The contact springs may have loosened just enough to reduce the battery connection to an intermittent state.
With needlenose pliers, see if you can gently squeeze the receiving contacts back together so when the battery registers with them they hold it firm.
Good diagnosis
Mike
Nov 20, 2010 | Bosch Drills
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
2) WONT TURN OVER AT ALL:
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
Why is my car trying to start when i attach the
Sounds like the starter solenoid is stuck on, most likely need to replace the starter, sometimes what can be done is tap the solenoid with a wrench or a small hammer and it may come loose, if it stops i would still recommend replacing the starter because it will happen again 9/10 times. Also check the wiring to the starter and make sure the start wire is not shorted or installed improperly. If there is constant voltage at the smaller start signal wire, the problem is somewhere in the wiring or the keyswitch.
Jan 25, 2010 | 1997 Toyota Corolla
My car won't start up and i got a good baterie
Are your battery connections clean and tight? The clicking sound indicates the solenoid is not engaging the starter motor. It could be either a bad solenoid or starter motor.
Nov 12, 2009 | 1998 Lexus Gs 400
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Phone shuts itself off
many of this problem are in the batery comparment, take of the batery and clean the batery terminal, then check the terminal batery conection in the cell if they are green thats the problem clean all and put the batery back...good luck I asume that you change your batery to your daughter celu..
Aug 03, 2006 | Samsung SCH-a670
Ao Safety PELTOR  ALERT  M2RX7A Radio Logo
46 people viewed this question
Top Ao Safety Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ao Safety Audio Player and Recorder Expert? Answer questions, earn points and help others
