Question about HP Computers & Internet
Im learning to use a computer .im not very good with a computer so how do i download a embroidery design and all info with picture to my documents?
  • 3 Answers
Go to this address -COPY FROM HERE (1.http://embroideryntailoring.blogspot.com/2008/10/flowers-butterfly-desing-embroidery.html 2.http://www.redleafsales.com/pics/ba1_large.jpg )TO HERE (INSIDE THE BRACKETS) COPY BY SELECTING THE SENTENCE AND USING CTRL+C ON YOUR KEYBOARD
Posted on Sep 14, 2010
I have a brother embroidery machine, and pe-design life software on my computer, I purchased a brother pes design cd from eBay which had really good reviews, but when I click on a design it says ( par
PE Design versions require certain OS'es, later versions work on newest WIndows 8. The PE Design software requires the right operating system and a CARD READER that also serves as a security device which allows the software to work.
Cheers,
Kelly
Embroidery Services
San Diego,CA
Jan 15, 2015 | Brother Sewing Machines
Transferring DVD designs to USB stick for my Husqvarna Designer 1
First you need your 4D software installed on your computer (or which ever version you are using). Insert the DVD into your drive. Then open your embroidery program and then click File and Open. When the new window opens, search for your DVD drive then find the embroidery you want and click Open. The embroidery yoiu chose should open in your embroidery program with the hoop displayed on the screen. Then save the embroidery under a new name in your embroidery design folder on your computer. Then insert your USB into your computer, Open Disk Manager and Read your USB. Then click on one of the empty squares and then click File then Open. In the new window find the embroidery file you saved under a new name on your computer and choose it. It should show up in the empty square you clicked on. Then Write to your USB. Now you are ready to move your USB to your machine and the embroidery should be there. Hope this helps. Good luck.
Oct 17, 2013 | Husqvarna Designer I
I have a Husqvarna 1+, how can I connect my laptop to it to download embroidery designs?
Sorry,... there is not a connection to allow you to do that. However there is a Reader/Writer unit that you can plug into a USB port on your computer and write a design to the card that comes with the reader/writer and then put the card in the machine to embroidery a downloaded design.
Doug
Aug 05, 2010 | Husqvarna Designer I
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
Embroidery card not working
I have definitely had this problem It just means that your orientation of the embroidery hoop is not correct when you load in the design.  I learned this through so much grief.  I knew the design was not too big for the card becasue it tells you the size when you do the design.  I did go buy a new card!   And the same thing happened.  Write back if you a step by step instruction.
Feb 28, 2009 | Baby Lock Ellure
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Downloading
The Designer 1 needs the design in an shv format in order to read it. The floppy disk for an older machine may be created using several different programs but the Husqvarna Viking module is known as Disk Manager. It is included with many of the HV software packages. With a newer USB Designer 1, the program is Disk Manager USB.
May 09, 2008 | Husqvarna Designer I
Embroidery downloads baby lock ellure plus
If not a USB model, you have to get the disgustingly expensive Babylock palette box ($500) and software with the blank card to transfer the designs from cd or files. Beware of making the embroidery too small, it can make the stitch density too great and then the machine cannot sew the design. There is software called Density Works to deal with this problem.
Apr 04, 2008 | Baby Lock Ellure
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
