Question about Whirlpool RBD275PD Electric Double Oven
Display F2 E6 error, then dead. Keypad realted? How do I remove control panel?
I have a Whirlpool RBD275PD Electric Double Oven. Out of the blue, the digital control displayed F2 E6 error. Following the manual, the off/cancel button blanked the display. Now nothing works but the light. Keys will beep, but nothing else happens.
I've read that the control panel connector may ned to be cleaned, but how do I take the control panel off?
  • alien10 Dec 10, 2008
    I had same error number/letter combination. I depressed lower oven off, per page 6 of manual to reset to clock after power has been restored. Didplay came up, started upper oven. Seems to be working OK now. Alien
    President:
  • 1,314 Answers
Fiest press the on key see if the display comes if not the turn the power off for 5-8 seconds if that doesnt do it turn power off then pull the oven out from the wall and remove the top to acess eoc pull the mylar ribbion out of the eoc by releasing the latch which is a tiny pullout bar at the base of the connector at the eoc then you cam clean the ribbon gently with a clean pencial eraser also under the top panel will be a tech sheet with more info pay atten to resseting the oven cavity size on start up
Posted on May 16, 2008
I just replaced the control board on this whirlpool double oven. It powered up fine but then went to an error code E1 F2. I've double checked all connections and they are fine. Is there a reset...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch).
Jan 29, 2011 | Whirlpool RBD275PD Electric Double Oven
Tip
Related: F2 E6 on Whirlpool RBD305PDS14 double oven - blank display
Equipment is Whirlpool double oven RBD305PDS14 built-in.  After a very stormy summer 2007, I thought a power surge may have zapped the control board.  Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit).  No error & fault code would appear.  Pressing any keypad oven control did not work at all in this condition.  When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
[TURN OVEN POWER OFF AT BREAKER!!!]
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed).  It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet).  The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol.  I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector.  VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power.  So far, so good.  After applying power, the "PF" with clock display always appears.  I am able to set the clock and press "Start".  Over functions normally.  The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however).
on Oct 21, 2007 | Whirlpool RBS245PDS Electric Single Oven
Oven is not working and there is a error mesage E6 F2
Hi, to fix this error follow the instruction below..
  • Check keypad connector for firm connection (keypad connects to control board).
  • Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 06, 2010 | Whirlpool RBD275PD Electric Double Oven
Oven does not work at all sometimes it beeps and has a fault code that reads E6 F2
Hi, to fix this error code follow the instruction below...
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
My display panel doesn't show lights. It will beep when I touch the clock, etc., but no lights. The inside oven light will come on. How can this be fixed?
This is a failure in the control board. It can be rebuilt by fixyourboard.com to save money vs. buying a new one. It is often an intermittent problem and sometimes accompanied by a random E6 F2 error when (or if) the display comes back on.
Aug 15, 2010 | Whirlpool RBD275PD Electric Double Oven
I have a Whirlpool model RBD275PDB12. I am
Hello,the error E6 and F2 you are receiving could be describe as "Cancel Key line open".Follow the following steps
1. Check keypad connector for firm connection(Keypad connection to control board).
2. Press CANCEL if error code returns after 60 seconds,replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replay control board (also called ERC or clock).
TThanks
Jun 03, 2010 | Whirlpool RBD275PD Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
Whirlpool RBD305PD has error F2E6 error on control panel
When this code appears and display is going blank too, it is always the control board. The only option is to buy a new one or get it repaired. It can be fixed quickly and reliably. www.fixyourboard.com
Apr 02, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBD275PD Electric Double Oven Logo
890 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
