Question about Acer Aspire 5920-6727 Notebook
I have a problem my laptop does not turn on. i push the power button and the light is on but the laptop does not turn on thanks billys
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
Have a frigidaire dishwasher number FFBD2406NS, has power to the washer it self but none of the lights turn on once pushed to lock the door.
Good Afternoon Billy, thanks for your submission!
I understand that your Frigidaire dishwasher, FFBD2406NS, is receiving power but no lights work once the door has been closed and locked. There could be an issue within a wiring harness, door lock, or control panel. Since it could be anyone of these underlying issues I would suggest having a professional technician to perform a proper diagnosis. This will prevent you from purchasing any unnecessary parts. Hopefully this information is helpful towards your repair. -Matt
Mar 21, 2016 | Frigidaire Dishwashers
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Jul 06, 2010 | Motion Computing C5 Tablet PC
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
No power at all even if i press the power button
Most likely the only thing wrong is the power button. Try to either replace the power button board or use a wire to short circuit the two points under the push button to turn the machine on.
Jan 31, 2009 | Toshiba Satellite A135-S2266 Notebook
Acer 5580: No lights, No turn on, no power up.
restart u r laptop and press f8 button when u r laptop start in starting press f8 and then restore u r system and again install u r driver after uninstalling
Oct 18, 2008 | Acer Aspire 5580 Notebook
Will not turn on. Toshiba 2060cds
I am having a hard time finding the manual for this older laptop, but, there is always a power button somewhere on the laptop itself, on the side, front, top of the keyboard, push everything and anything till you find it. Just plugging it in will not turn it on.
Apr 06, 2008 | Toshiba Satellite 2060CDS Notebook
Hitachi 43FDX10B Power problem
Below is a few possible causes along with verified cures.
Symptom:
Intermittent shut off
Cause: Check auto link and 4 event timer. redress cabling from front control panel away from blue crt-yoke-hv lead
Symptom: NO PIC OR OSD, PWR LITE COMES ON
Cause: CHECK C603 LEAKY
Symptom: shutdown
Cause: T701
Billy
Jan 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Acer Aspire 5920-6727 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
