Question about Vacuums
I have a Toro LX425 lawn tractor with Kohler engine. I just noticed the oil light started flashing and CH6 was being displayed
Huskee LT4200 42" Lawn Tractor
Talk to the dealer on this.
Jun 07, 2016 | Vacuums
Evrything is clean or new. bag filters hepa ect. the problem is i plug it in , it fires to life straight away without the customary flashing green lights and lift of the vacume handle , then runs for
Not knowing what kind of vacuum and not having enough details for a definitive answer it seems you may have an obstruction somewhere that is restricting the airflow. Sometimes they can be very difficult to locate. Start where the dirt collects, in the bag or dirt cup depending on what vacuum you have and work your way through the vacuum trying to locate a clog or obstruction.
Jan 14, 2015 | Vacuums
My check engine light is on code P0523
check all your connections first. you really need to make sure they're good. this issue is not for a rookie because it can come down to a defective PCM... But if you are willing to try and fix it right then
http://www.gmforum.com/obd-ii-trouble-shooting-153/p0523-286000/
be very careful and make sure you have the proper tools and wiring diagram for this circuit !!!
Dec 28, 2013 | GMC W3500 Pressure unit. oil....
Need to replace main drive belt for sickle bar
Instructions
Put on your work gloves. Check the frame size for your mower. It will either be a 56-inch frame mower or a 76-inch frame mower. When you have determined the frame size, adjust the tractor's rear wheels to the mower's frame size. For 56-inch frames, adjust the rear tractor wheels to 56-inch centers or less. The same rule applies for 76-inch frames.
Back the tractor into a position where you can align its left lower link to the mower's lift link pin. Attach these two parts together and secure the connection with the tractor linchpin.
Roll the tractor and adjust the leveling crank until the tractor's right lower link can be attached to the right link pin on the mower. Use the tractor linch pin to secure the connection.
Attach the upper link from the mower to the lower hole in the tractor rocker arm by using the link pin.
Start the tractor. Using the hydraulic control lever, lift the mower frame assembly slightly and move the mower to the left to allow attachment of the left stabilizer. Place the stabilizer guide under the tractor's left lift link. Position the clamp over the link and tighten the nut firmly
Depending on the tractor type, install the clamp plate or push rod anchor assembly onto the left lower link. Install the push rod on either the clamp plate or anchor assembly.
Shift the mower assembly to the right to attach the right stabilizer. Place the stabilizer guide under the tractor's right lift link. Position the clamp over the link and tighten the nut firmly.
Raise the mower using the hydraulic control, then attach the mower lift spring to the spring links with the pins that have been provided. Lower the mower assembly and turn off the engine.
Remove the tractor power takeoff (PTO) cap and connect the splined end of the mower's drive shaft to the PTO shaft. Secure the connection with the snap coupler found on the yoke.
Rotate the leveling crank to lower the frame, ensuring that it is parallel to the ground. Use the leveling crank lock to secure the crank lever.
Jul 15, 2012 | Vacuums
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Hi, I desperately need a service manual for my Suzuki M120X lawnmower engine.
Try this link. Manual is for a Toro mower with a Suzuki engine. http://www.scribd.com/doc/38652193/Toro-2-Cycle-Engine-User-Guide
Aug 14, 2010 | Vacuums
Craftsman lawn tractor model 917.270821 ( Auto trans)
Check the fluid level in the transmission. If the fluid level is low, the trans will act as if it's slipping.
Nov 25, 2009 | Vacuums
How to reset service reminder after i changed oil and filter after a week the engine light came on and derated the engine power
That is not a service reminder. The light comes on when there is an emission/engine control related problem, either with a sensor or engine management component. Go to a car parts store that does free testing (like Napa, Auto Zone, Kragen/O'Reilly's, etc.) and have the code scanned. From there, you will be able to research the code online or come back and ask what could be causing the problem here.
Nov 04, 2009 | Vacuums
"New" Rainbow Eseries flashing red light
This is fine it is an indicator light that the computer is working.
Feb 24, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
161 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
