AOG45APA3L HAS DAMAGED POWER CIRCUIT BOARD - Heating & Cooling
2 Suggested Answers
SOURCE: no power or lights and circuit board looks like it
buy a new on and in two or three months take back the old and ask for a refund
Posted on Apr 14, 2010
What would cause a black screen on vizio LCD Tv? I have sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 14, 2017 | Vizio Televison & Video
LG tv 55GA6400 has sound but picture keeps going black after a minute or so.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 13, 2017 | LG Televison & Video
Vizio tv 37" picture started to get darker
Jan 11, 2017 | Vizio Televison & Video
The top quarter of my philips lcd screen is fine but the rest is sort ov blured hazed, a bit like if the screen got water damaged.
Nov 11, 2016 | Philips Televison & Video
Won't power up or light up
1. Change power cord.
2. If Power cord is ok then Internal circuit board is damaged.
3. If circuit board fault then you should consider to television technician.
Nov 17, 2013 | Proscan 32LA30Q Television
Power supply board damaged by lightning would like to purchase another one
Damage due to lightning would not be limited to power board only, in my opinion, other circuit board would have also been damaged so new home theater system would be good choice rather repairing this one.
Thanks.
May 27, 2011 | Oritron DAV3101 PROGRESSIVE SCAN DVD
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
Feb 26, 2011 | Hitachi Computers & Internet
Loud humming sound. Blown power adapter transformer. Bought new adapter same humming
The power adapter that blew damaged the amplifier circuits inside the sub (or a damaged circuit caused the power adapter to blow)... in either case, if you have electronic skills and access to a oscilloscope, you can trace the signal on the circuit board. The suspect components to look for would be around the connectors for the power supply to the circuit board.
Apr 08, 2010 | Altec Lansing AVS 500 Computer Speakers
Clicking noise in the circuit board and everything in the freezer is thawed
Hi. this will be a failed relay on that circuit board. This is called the PCB(main unit power control board). This board controls the compressor relay functions, and the compressor power current, as well. The evaporator fan, and condenser fan, receives their respective current from this power control board, also. When a circuit board of this nature begins to malfunction, it will cause the unit to not cool properly, due to limited, or no fan actions, or a failed compressor cycle. I would recommend to replace this damaged control board, asap.
Dec 04, 2009 | GE Freezers
Power surge, TV will not turn on
Power surges are extremely unpredictable, they can damage everything inside the tv, from the power supply printed circuit board, to the main printed circuit board. Normally the power supply takes alot of the damage from these things, so check over the power supply for any damaged components, any burnt out parts on printed circuit board, and also check the fuse. Good luck.
Aug 28, 2009 | AOpen Televison & Video
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
