Question about Epson DFX-9000 Dot Matrix Printer
Error : paper jam Epson DFX-9000 - Epson DFX-9000 Dot Matrix Printer
I find problem printer epson dfx-9000 with mesage
error : 0E
turn off printer
help solution this problem ????
Posted on Dec 03, 2010
I have printer epson dfx 9000 with paper jam error
Posted on Jul 14, 2015
Paper jam error
check your printer if there is anything paper stuck
clean it maybe there is dirt that causing paper jam.
and if the same problem. plss check the paper jam "sensor"
Apr 24, 2014 | Epson DFX-9000 Matrix Printer
Error 13 on epson dfx 9000 printer
Hi Good day!!
Error 13 is a printer error code that signifies that there is a paper jam. You need to check the jam in the entry if your system shows this error. Error 13 also indicates the need to replace the pickup roller in the printer.
Aug 29, 2012 | Epson DFX-9000 Matrix Printer
Error 01 0n epson dfx 9000
i have a problem on my printer epson dfx 9000 with erro code 01 turn off your priner any one with solution?
Aug 29, 2009 | Epson DFX-9000 Matrix Printer
Epson dfx-9000 printer is showing error 0D when it is switched on
check print head built in thermistor and the carrier cable.
Nov 20, 2008 | Epson DFX-9000 Matrix Printer
Dfx9000
Internal hardware detects that the paper paths do not switch during paper path switching operation.
Check HCPP sensor or call for service.
Phone Number:
(562)276-4322
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 08, 2008 | Epson DFX-9000 Matrix Printer
Papaer out error
Paper detection switch on tractor feed unit is probably faulty. Replace the tractor feeds.
Jul 15, 2008 | Epson DFX-9000 Matrix Printer
EPSON DFX 9000 DISPLAYING ERROR O F
This error occurs when the Home Position (HP) of the Automatic Paper Thickness Control (APTC) mechanism is not detected.
This error is caused by a malfunction of either the APTC HP sensor circuit, the APTC motor, or the driver circuit on the ROM Board.
Check the following in the order below, testing functionality at each step. If the APTC motor has malfunctioned, be sure to check the motor driver circuit on the ROM Board before replacing the motor.
1. Check connectors CNSEN1 and CNSEN2 on the ROM BOARD.
2. Check and replace the APTC HP UNIT
3. Check both the APTC motor, APTC UNIT, ROM BOARD, and replace either or both as necessary.
Get a service manual HERE if you need it.
Jun 25, 2008 | Epson DFX-9000 Matrix Printer
Error code 14
Error 14 hccp sensor malfunction- Its the sensor for detecting paper if its coming from the rear or front.
Chances are if you are getting the error even when your paper and setting is set correctly, you will have to call servicer or Epson so that if its within the warranty they will have if fix for free.
Pls dont forget to rate solution, thanks!!
Apr 29, 2008 | Epson DFX-9000 Matrix Printer
DFX 9000 error oC
09 : FAN1 driver error
0A : FAN2 driver error
0B : FAN3 driver error
0C : FAN4 driver error
Jan 11, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-9000 Dot Matrix Printer Logo
1,641 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
