Question about Toshiba Satellite A305-S6845 Notebook
I have a problem with my laptop toshiba a305-S6825, everytime i plug in the ac charger the laptop shuts down and reboot. I can only use the battery. I have to shut down the laptop everytime so i can charge the battery. I borrowed a new charger from a friend with the same type and voltage rating but still the problem not solved. I already replaced the thermal paste in the cpu and already checked the fan, i've found nothing wrong with the fan, it is functioning well. Please help me solve this problem
  • Michael Nicolas Feb 09, 2013
    hi sir/ma'am did the solution fix it?we have same problem.can you help me regarding this issue.thank you. email me at frozenheart18@ymail.com.
  • 3 Answers
Try to press start button and then search for device manger then click on the battery and find out its condition wither it needs to be replaced or it may some programmes need to update by pressing trouble shoot
Posted on Sep 14, 2010
My Toshiba L200 when i plug adabtor it always shut down. if i use with battery is use normal but when plug adabtor it shut down,what can i do?
First double check your charger is 19V (at 3.42A minimum) on the body label. It could also be providing a faulty voltage so you need to check its output with a cheap voltmeter (should be 19 to say 22 volts off load), OR borrow a 19 v charger from someone which has same connector to see if it works on your laptop. Good Luck.
Dec 23, 2014 | Toshiba Satellite A305 A355D L200 L305...
The labtop doesnt boot when the charger is placed in and it also goes of when the charger is put in
Is the AC cord the original? Has it been damaged? Have you tried another AC cord, with the EXACT same power specs? It may be a damaged AC jack. Sometimes a pull or tug on the cord while plugged in will loosen the connection. If you wiggle the cord at the jack plug does it cause the charge LED to blink? Does the computer work on battery?
Nov 28, 2013 | Toshiba Satellite A305-S6863 Laptop
Toshiba Laptop Dead no bios
Most of laptops batteries have electronics inside them wich test and transmit info about the battery itself. Maybe the fail is there and not in the laptop. Try with another battery befor dumping it.
Dec 01, 2012 | Toshiba Satellite A305-S6859 Notebook
Shuts down after a few minutes
Try another battery.
If it's doing this while plugged in, there's probably failing electrolytic capacitors in the external power unit. Repair or replace it. Chances are the power supply will test as good under no load.
May 15, 2012 | Toshiba Satellite A305-S6825 (4400 mAh)
Where can i find a cord for toshiba satellite 8305-s6829
If you are referring to the AC Adapter, you can find out here:
http://www.buy.com/prod/new-ac-adapter-for-toshiba-satellite-a305-s6825-a305-s6829-a305-s6833/q/sellerid/24353325/loc/101/214314182.html
Otherwise please specify the type of cord you are looking for.
May 05, 2011 | Computers & Internet
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
Toshiba Satellite A305-S6845 Notebook Logo
371 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
