Question about Dishwashers
Could you please tell me what errors 6, 24, 26 and 10 are on the winterhalter uc-m glasswasher please?
2 Suggested Answers
SOURCE: could you please tell me what error codes 21 and 6
error 6 relates to a blocked drain pump. if the drain pump is working ok check if the tank level sensor is operating or if the air chamber in the wash tank is blocked.
error 21 relates to the drain pump being activated. normally related to error 6.
also check water inlet solenoid valve is working correctly. ie not blocked or passing.
all parts of the machine can be activated manually by entering service mode.
when machine is off press service button or switch on main pcb.
p00 appears. press and hold main wash button. --- appears. using the long and short wash buttons you can scroll through parts of the machine. displayed as a01 a02 a03 etc.drain pump is a12 solenoid valve is a13. these are activated by pressing the button. when activating the drain pump the display will count down. this number is the water level in the wash tank. if it's counting down the level sensor is ok.
hope this helps
jarv
Posted on Sep 28, 2010
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
WHAT DOES ERROR CODE 6 MEAN
I'm thinking the drain is plugged. Good Luck.
Nov 24, 2013 | Washing Machines
Samsung washing machine error code uc
Since you are receive UC error code, Please call the after-sales service.
Source: Samsung CS Portal
May 24, 2013 | Washing Machines
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
Error code 23 on winterhalter gs 502
hi i a have a problem with dish washer it shows error 23 .and the ,model is GS 502,GS 515 .So how can i rectify the problem .thanks in advance.
Dec 28, 2012 | Dishwashers
Error code 16 on winterhalter gs302, any ideas please?
Error 16 on (E) versions is low water flow, recommend checking the water inlet pipes and water supply is fully turned on, that the water solenoid valve is functioning ok and that it is not blocked with debris (they have a filter on the water hose connection side), and that the inlet water pipe is not blocked, squashed or kincked.
Apr 09, 2011 | Dishwashers
Hi, could someone please let me know what error code 51e means on hobart gx7 glasswash machine? Oli
....The error code doesn't say "51E", it says "SIE". Take out the strainer from your wacher and place it the right way (probably turn it 180 degrees)...see http://www.cateringequipmentandrepair.co.uk/docs/Hobartglasswasherservicemanualfx-gpfpgd.pdf
Aug 22, 2010 | Hobart 29 in. AM15-1 Free-Standing...
DISHWASHER INSTRUCTION MANUALS
please contat winterhalter regional office or headquorter on
info@winterhalter.biz
Nov 14, 2007 | Washing Machines
Dishwashers Logo
2,121 people viewed this question
Top Dishwashers Experts
