Question about Acer Aspire 5315 Notebook
I need battery for my laptop - Acer Aspire 5315 Notebook
  • 3 Answers
What does the internal 601 Battery do, and how to replace it
Do you use your power off the mains at all (not plugged in) It will be the main battery for the laptop.
If you always leave your laptop plugged in there isn't much point in getting a new battery. Perhaps you can turn off the error message on startup?
Feb 27, 2014 | HP Pavilion dv7-1129wm Notebook
Tip
How to take Care of Your Laptop Battery
BATTERY 101 PART 1
What really makes the Laptop or Notebook really portable is its Battery. Remove the Battery then you are indirectly removing the Laptops portability. As human beings we need energy to survive which is form of the food we eat. Similarly a Laptop needs energy to survive. The energy a Laptop needs to survive comes from the Battery which is made up of chemical juice (Lithium Ions). This chemical juice operates optimally at particular conditions. Hence we need to take care of it. Now if you take away the battery of a Laptop, you are taking away the life of the Laptop. We can then understand that it is the battery of the Laptop that keeps it alive.
Since Battery = Life of Laptop it simply means that No battery = Death of Laptop. Because batteries are so important in the existence of a Laptop we definitely have to take care of our Laptop battery.
HOW TO TAKE CARE OF YOUR LAPTOP BATTERY
I observed that many Laptop owners do not really care for their Laptop batteries. You might wonder why? It is simply Lack of information. So i am going to be giving you several tips on how to take care of your Laptop battery. I am going to cover two tips in this Part of the article and continue in subsequent parts. So watch out for Part 2.
TIPS
1) NEVER ALLOW BATTERY TO DRAIN COMPLETELY
Lithium ion battery is the technology used in modern Laptops. Squeezing every drop of its juice (chemical) weakens and strains the battery. Hence cumulative drain of the battery will shorten the life of the battery and eventually kill the battery.
2) NEVER ALOW THE TEMPERATURE OF THE BATTERY TO BE TOO HIGH OR TOO LOW
High temperature breaks down the battery and reduces its overall life expectancy. Always make sure the vents are unblocked and also never work with a Laptop on the cushion because if you do so you will be blocking the vents in the Laptop. If you are wondering how to check the temperature of your battery you could get a software to do that.
on Sep 11, 2010 | Computers & Internet
My battery won't charge even if I replaced it with new battery.
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
http://www.chargerbuy.com/laptop-battery.html
Jan 14, 2013 | Computers & Internet
Charging led blinking
with a new one.
To test the laptop:
Dec 02, 2012 | HP Pavilion dv9000z Notebook
Why will the battery not charge?
To test the laptop:
Nov 27, 2012 | HP G60-120US Laptop
Acer 5742 will not charge the battery
Before you replace the Mobo, test the battery and try another cord/charger of the exact type/power specs. If the AC jack is damaged, due to a pull, yank, tug....etc. on the cord, the AC jack may need replacing. It's difficult to say for sure, without eliminating other factor, the ones I mentioned. I assume a QUALIFIED computer tech told you the Mobo needed replacing??? Is the battery a replacement? Is the cord original?
Nov 23, 2012 | Acer Computers & Internet
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
My computer is not starting on battery suddenly after a night while battery is full charged
Take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Aug 30, 2010 | Computers & Internet
New battery needed. Need to format laptop.
You can still use your laptop even if your battery died & could not be recharged any longer. Just remove it from the laptop, & power the laptop directly from its power brick till you get a replacement battery.
Dec 05, 2009 | Dell Inspiron 6400 Notebook
Acer Aspire 5315 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
