Question about GE Dishwashers
Hi, we own an old VDB2010KC119 ser:KES79829. The bottom jet/propeller is still shooting water but it does not spin around anymore. It is not jammed in place and can be moved manually. Is this worth fixing?
  • GE Master
  • 909 Answers
You need to remove the rotor and inspect the holes on either side. If there are 5 holes on the left hand side there will be 5 holes on the Rhs. Every hole has to be completely clear of blockage or the rotor will not rotate. Make sure not even one is blocked. Check to see if rotor spins nicely when flicked and make sure it doed not touch anything when operating(washing). That should definately sort the problem out.
Posted on Sep 14, 2010
Pool cleaner will vaccuum but no movement in pool. plenty of water pressure going thru back hose
Before doing anything, take the Jet Vac out of the pool and set it on the deck. Stand clear and turn it on. It should have enough water going through the blue jet to spray several feet and propel the jet vac on dry land.
What propels the Jet Vac is not the water going through the hose, but the water going through the little blue Jet under the Hose. You can unscrew this from the bottom of the shell and clean out any obstructions. Also, check the screen at the connection where the hose meets the wall. It is located in the white valve with the red button on it right at the pool wall. It will unscrew from the wall of the pool with the system off. Also make sure the booster pump is coming on.
Also, it may be stuck in reverse or neutral. If this is the case there will be jets of water shooting forward of the jet vac when it is on dry land.
Apr 15, 2011 | Pentair Jet Vac Venturi Shell Blue Jv2c
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
My dishwasher is aprox. 9 years old and has always worked fine. on the last load, a hard scum was left on everything....any suggestions??
You can get dishwasher descaler crystals to flush out and clean the machine.
Make sure the water jets are not blocked. you can use a sharp object to poke the holes and free them up if they are blocked. Also make sure when you are loading dishes, they are not resting on the water jet propellers and they move freely.
Also remove the bottom tray filters and clean thouroughly.
Hope this helps.
Ash
Oct 22, 2009 | GE Dishwashers
The bottom water "propeller" won't go around, although the motor still goes...
Remove the bottom water jet and clean everything. Usually, there are tabs on the sides of the base to release it.
Jul 31, 2009 | Maytag JetClean II MDB8551 Built-in...
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Upper arm does not spin on Frigidaire model # FDB635RFS6 dishwasher. I cleaned screen around sump and rinsed out arm. Arm is not physically obstructed. Suggestions? Thanks!
OK, the arm is jet-propelled, so it will spin if it is free to rotate and has water squirting down into it. If it >is< free to rotate, then either the water isn't squirting, or it is missing the target. On my machine - different brand - the guide cone came loose when I dismantled the upper bar assembly and it hadn't gone back correctly aligned, so the water missed the hole.
I'd check that first. D.
Jul 31, 2008 | Frigidaire Dishwashers
Bosch logixx slimline dishwasher, the bottom washing jet arm no longer osculates we have cleaned the filters thoroughly and checked the jets but it is still not rotating. Any suggestions at getting it...
does water emerge from the jets if yes than maybe somthing broke such as a propeller that cause dit to spin under water supply pressure?
Mar 13, 2008 | Dishwashers
Bottom wash arm
there is a blockage but may not be obvious. arm turns only by water spraying out of the angled jets at the end of the arm. take arm off, run water thro the centre hole and this is udually enough to force the debris to the jets. clean out and check
Jul 08, 2007 | Tricity Bendix 18 in. DH090 Free-standing...
Dishwashers Logo
18 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
