Question about HP rp5000 PC Desktop
Hi. When turning computer on it beeps 5 times, pauses and beeps 5 times
  • 734 Answers
HI there,
You might want to review the page at the link below. If you're just getting the beep code and no boot up I feel fairly sure you have a serious hardware failure of a majot motherboard component (CPU or Video card possible).
Regards,
Marcus
Posted on Sep 14, 2010
3 Suggested Answers
SOURCE: computer won't restart....
it appears that this is a memory problem, based on the codes that you specified.
the reference for this is:
http://support.dell.com/support/edocs/systems/dim3100/en/sm/adtshoot.htm#wp1124996
Posted on Aug 09, 2009
dante777
  • 623 Answers
SOURCE: Hi we have a HP
You did not mention which model (or BIOS) you have, so all I can do now is to point you to HP's support page (link is here), which explains the different beep codes.
Some good solutions are also mentioned here.
Usually it is a sign that there is a hardware failure and you should carefully check your hardware components - if you can't do it yourself, you have to find someone who knows about it.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Sep 19, 2010
Computer won't come on
All computers have beep error codes, if you provide the following details I may be able to help.
1 Make and model of PC
2 error code ( you can count the code for example: 123 could correspond to
Beep - pause- beep beep - pause - beep beep beep
3 does the fan turn
4 does the monitor turn on ok
5 can you hear the hard drive an DVD rom spin a little then go quiet or do they spin and then chuntle on for a little while
Nov 25, 2016 | Computers & Internet
Dell inspiron 1545 14 beeps (more details inside).
This indicates a motherboard issue, sub out the ram memory one at a time, test each as you go, if no change! The motherboard will need to be replaced, or the laptop.
Apr 21, 2012 | Dell Inspiron 1545 Notebook
THE RED LIGHT IS ON AND BEEPS EVERY MINUTE
What motherboard do you have? If you don't know, provice make and model of your system and maybe we can find out that way. Is it one long beep? Are there any other beeps and/or a sequence. A good place to start and alot of times, depending on your bios, 1 to 3 beeps means a problem with the RAM(memory). If you have more than 1 stick, you can pull them out, restart and if the beep is the same, you've probably found your culprit. You can then insert one at a time in one of your slots, then restart. If this works, you've found a good stick. If not, try another slot and restart, etc. Try all sticks in all slots.
Apr 06, 2011 | Computers & Internet
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
Sep 09, 2009 | Acer Aspire X3200 PC Desktop
Computer won't restart....
Aug 09, 2009 | Computers & Internet
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
Computer will not come on
beeping 4 times in a row is a hardware problem
repalc motherboard if video is intergrated
Mar 26, 2009 | IBM ThinkPad T30 2366 Notebook
Beeps coming from over by the glove box after turning engine off.
the beeps are an airbag trouble code, that code is for the following:
In most cases this problem is caused by the rotating ribbon circuit contact under the steering wheel having a broken filament, the part is known as a clock spring contact, u will need to properly disarm the airbag and remove the steering wheel to access the part. WARNING: Failure to follow factory Airbag disarming protocol can result in an unexpected Airbag deployment and possible serious personnel injury or death.
Mar 13, 2009 | 1998 Ford F150 Regular Cab
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
HP rp5000 PC Desktop Logo
485 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
