Question about Dayton Heating & Cooling
Inefficient (big, yellow flame) on wall propane heater, using up propane too fast
I have Dayton propane wall furnace. (Its 20 years old). Last yearwe went through 250 gallons of propane in 14 months. (We use wood heatprimarily, and have small tank-less water heater). This year wewent through 250 gallons in 6 months, barely used heater. It hasa big yellow/orange flame, and there was all this very fine black sootin bottom. I knew enough to know that the oxygen /propane mix iswrong, and a repair man did a Carbon Monoxide test, which read zero, sohe said the heat exchanger is not cracked, and although there's quite abit of sooty buildup, he doubted the flue was blocked. Yesterday,I cleaned out as much soot from top of heat exchanger as I could, and ahome book suggested removing/cleaning burners, and adjusting 'setscrew' to change mixture of flame. The diagram in book lookednothing like the way burners are installed, and I was unable to tellwhat and if there even was such an adjustment for propane/oxygenmixture. I realize all the sooty ash could be clogging burnersexacerbating problem, but I believe the soot is a result, not thecause of the inefficient mixture. I did notice when I turned pilotto "off", it did not go out for over 10 minutes and I had to blow itout. Is there something else I can look for on gas/safety valveto adjust, or can you tell me how to remove the burners to cleanthem? (They are up even with pilot light, which is behind panel onheater/has a little hole for lighting, but difficult to even see burnersurface.) Repair man is coming back to test gas pressure at tank, atheater (with hot water running although tank-less water heater wasinstalled 3 years ago and seems completely unrelated to furnace problemthat started 6 months ago), said the diameter of gas line at tank maybe too small or too big (although its been fine for 20 years). Isuspect its the safety/gas valve but I have no manual...Any suggestions?
  • Anonymous Mar 27, 2014
    rinnai r85 exterior propane tankless water heater makes knocking/clicking noise. seems it tries to start with clicking noise then no fire in burners then cycles again. no error message. have two rinnia side by side other works without issue. not sure if safe to sssume gas pressure is fine. took out fan,air cleaned it,checked vent no issues. air cleaned burners,no build up where pretty clean from last cleaning 6 months ago. coils cleaned. cleaned spark and flaming rod. pieces all put back same issues. not sure how to troubleshoot to ensure gas us going in system. also to ensure spark rod is working. win d ow into burner is pitch black just cycling of clicking noise.
  • 1,420 Answers
A clue to what could be wrong is that you mentioned it took 10 minutes for the pilot to go out. It could be your gas valve. Get a technician in to check your gas pressure both before the gas valve and after. Have them check it as the water heater is running.
Posted on May 16, 2008
2YV14 need to find a new replacement fan blade and hub for a dayton wall heater model #2YV14
Hello Jeffrey Messenger,
Dayton is a big name product available at GRAINGER.
Electric Wall Furnace,
Recessed or Surface, 240VAC, Watts 9200
Replacement Parts
H
elp finding replacement parts?
Please call 1-800-GRAINGER
(1-800-472-4643)
The 2yv14 is a well known heater... sadly it has been
MANY years since I have purchased any
Dayton equipment... but GRAINGER RETAIL
OUTLETS WERE The reliable PLACE TO GO.
(see below).
GRAINGER
https://www.grainger.com/category/dayton/ecatalog/N-1z13ntg
DAYTON-Electric-Wall-Furnace-2YV14
Electric Wall Furnace Recessed or Surface 240VAC Watts 9200
Carnac the Magnificent
Mar 22, 2017 | Dayton Heating & Cooling
I have a Dayton 3E290 wall heater that was installed new 30 years ago. The pilot light started to extinguish a few years ago. Gradually this began to occur more frequently. I've changed the...
The pilot assembly may need cleaned out and the orifice cleaned, also the gas valve may need to be replaced, to check for proper voltage from the thermocouple you need a flame source and it takes a meter that can register DC milliamps, and should be 350 to 750 millivolts. Heat the thermocouple with the pilot or other flame source and check, if OK, gas valve is weak.
Nov 02, 2011 | Dayton Gas Furnace Heater
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
What color should the flame be on a coleman
hi the gas goes along aburner tube then comes out of the burner then it hits a baffle in side the heat exchanger as long as there is not sooting the flame will look yellow , i would say the best thing would be to contact the makers of the furnace direct they should have a technical department , they might be able to offer more help or have there own people to look at the heater most of these companys have a warrenty on there heaters
Jan 09, 2010 | Coleman Propane Forced Air Heater...
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Mar 31, 2009 | Coleman Propane Forced Air Heater...
I have a coleman propane furnace in my home that is 30 yrs old. you can light the pilot but when you turn up the thermostat so that the burner will light and the fan will blow the pilot goes out after a...
watch your flame on the burners and see if the flame changes when the blower starts if it does and makes the flame jump around you have a busted heat exchanger
Nov 22, 2008 | Heating & Cooling
Heating & Cooling Logo
1,348 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
